Old 10-04-2013, 01:02 AM   #1
bmcnult19
bmcnult19 is an unknown quantity at this point
s13 S13 Clutch Line Issues
Alright so here's the deal... I'm rebuilding my S13 hatch and I've recently put in a new clutch line. I know the slave cyl is good, because it worked before I changed the line. The problem is that when I go to bleed it bubbles come out for days. I sat under it sucking bubbles out for literally an hour or two. Is it likely a problem with the master cyl? That's the only part I don't know is good.
BACKSTORY: I had two master cylinders, one from my old 91 and one from the new-to-me 92 that was still in the car. When I went to swap the 91's KA into the empty 92 I just assumed it was fine.
It's been sitting for over a week "gravity bleeding" and I guarantee when I go back the petal will sink to the floor with almost no resistance.
Also does anyone know if the master cylinders on RockAuto are any good? They're only like $20.
bmcnult19 is offline   Reply With Quote
Old 10-04-2013, 02:27 AM   #2
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
is the new clutch line your using steel braided and if so what brand?
ive heard isis braided lines "lower cost,inexpensive,no name brand" that have came new with air leaks so properly/fully bleeding the brake system would be impossible...
but then again im not sure if thats ur problem.
if your running an oem line disregard what i mentioned*
Renelovesnike is offline   Reply With Quote
Old 10-04-2013, 03:42 AM   #3
zerodameaon
zerodameaon's Avatar
Please post in the correct section. Not rocket science to figure out what one I am talking about.
Need to adjust your idle?
#/f/s-chassis/395413...-pictures.html
bleeding procedures, clutch line, clutch master, s13 240sx ka24de ka24e
