flip up headlight conversion
just wondering if there is a write up anywhere on putting fog light into flip ups and leaving them as lazy eyes how hard is it and what do you need? like this click me
![]() Join Date: Dec 2004
Simple, just think.
Buy some PIAA driving lamps, MSRP @ 250 or so. should come wth mounting brackets. Mount lamps onto headlight cover, open up the headlight pivot control, make it lazy, unplug, or never use highbeam. |
#4 | |
Admin Asshole
![]() Join Date: Mar 2002
Did you not see the post I made in the Gallery?
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#6 | |
![]() Join Date: Feb 2005
+1 for effort though. p.s. that video is on 240sxforums.com in the DIY forum. |
![]() Join Date: Jun 2002
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
they are designed for what they are named. for FOG. not for driving. |
PIAA also makes driving lamps, higher intensity lamps.
Bright, but eye-catching. Clean, but ill-eagle. I would do that to my car, but i have neither the funds, or the intention of gettin pulled for those headlights. Tell us how much you get fined for them. =] |
i did the PIAA headlight/foglight thingy. I used the PIAA P-3000 driving lights/foglights combo for a dual effect, and for those that say that foglights don't offer enough light, you are semi correct. The driving lights are angled a bit higher than the foglights and can be used as "high beams" and the foglights can be used for regualr driving. The good thing about this foglight set up is that the fog lights is extremely bright, it is also extremely YELLOW. Driving around with yellow foglights as headlights draws some unwanted attention from the Pork-Crew. Aside from that, the foglights are very narrow in the light pattern. but if you are able to setup a relay to use both of the driving lights and the foglights, its DAMN BRIGHT!!! People will curse you and honk at you for havgin sucha bright setup. Also, with the sleepy eyes set up, your car will look extra sexy, with super bright driving lights.... it was an awesome combo that I miss dearly since I was getting the wrong kind of attention from cops.... but yeah..... buy the lamps, drill the lamp mounts, and mount those suckers on..... then BAM, you find yourself getting fix it tickets left and right! enjoy
Drag racing is for fast cars. Drifting is for fast drivers. |
I don't think people are cursing you because the foglight combo is bright, it is probably because its incorrectly aimed at the road and pretty much blinding anyone you encounter.
KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST |
as for the illegal part. i guess it all depends on where you live. cause in MD you could get away with it cause cops do not know shit about cars .
93 h/b. ka24de-t3(14), enthapy controlled .20bore, weistco 8.5.1cr, gReddy FMIC, E/L mani,t3 turbo to a 3in D/P to a HKS(88mm)HiPower and for cool sound effects the oldskool HKS Superblow, and you ask what about fuel? let me tell you 580cc, yes i said 580cc's, act clutch/flywheel. Buy my Coolio trading cardz! |
![]() Join Date: Jan 2003
http://www.rallylights.com/hella/90mm_modules.asp
Jesus, use these and call it a day. Anyone who uses auxiliary driving/fog lamps as their primary light source is a jackass. |
#15 | |
![]() Join Date: Apr 2003
^^ yup, that's the best way. that's what clearcorners uses too, and that's the reason
#16 | |
Admin Asshole
Your ignorance is blinding. Be sure and use that same excuse when you are standing in front of the judge. ![]()
#17 |
![]() Join Date: Aug 2003
trust me ...
if you are going to use fog lights for your headlights .. dont... you wont be able to see jackshit .. i did it a couple wks ago .. and its so bad .. i put it back to stock |
I did the clearcorners style setup. The light output is great, and doesn't blind anybody.
I would never use foglamps or driving lights for my main lighting. The beam pattern is crappy and doesn't travel as far as it should. Another thing, there is no cutoff in the beam at all. The hella's have a really defined cutoff, and when aimed correctly, the cutoff is right below the rear window of most cars.
Scott Driving Angle Motorsports |
