Future Ka-t hopefully
Sup guys so i have a kade with a blown head & i decided to pull the motor and rebuild it, full rebuild not just the head. I want to in the future go Ka-t but for the moment when i do the rebuild i want to run just Kade. But since im rebuilding and having it apart i want to prep it as much as i can for Ka-t later on. Do all i need is just forged pistons , rods & i believe cams and crank? I will be getting ARP bolts/studs. Im planning on reaching atleast 300-400hp no more than that. Any suggestions i can while i have the motor out? I will be getting it machined and resurfaced also the head and block. Any help please would be very appreciated.
I would just rebuild it with new oem head parts, timing chain kit and go with 8.5:1 pistons, rods and bearings get the crank cleaned up and balanced. You have to get it balanced as it isnt fully counter weighted. Metal cosworth HG and a new oem gasket set and new oem studs. With a t3 turbo like a gt3071r you will make easy 350-400hp at the crank and you will be very happy. KA-T.org is a good website to checkout aswell.
Forged Pistons/Rods, Metal HG and ARP fasteners are good to have at that WHP goal. GL on the rebuild.
#5 | |||
![]() Join Date: Sep 2008
Sounds like you have a good plan, Personally i dont think the cams are a must incase your on a budget. But Upgraded cams are always nice.
Personally, i bought a bran new head that was literally an OEM bran new one a guy had just put on his ka24e and crashed it 500 miles later for 300 dollars the whole engine. I took the bran new head with the block i built and mated them together and they work great. No problems what ever. May i suggest Arais pistons and Eagle Rods ? I personally have been running them and love em. Lastly, spend most your time at the machine shop when you get your pistons and rods.
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
