Old 02-25-2002, 08:06 AM   #1
black0ut
black0ut is an unknown quantity at this point
Send a message via ICQ to black0ut
Just a quick question. I am putting 225/45R17s on my car soon and was wondering how much if any my speedo would be off. Any help would be appreciated. Thanks!!
...contact me...
black0ut is offline   Reply With Quote
Old 02-25-2002, 09:33 AM   #2
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
When your speedo  reads  60mph, you'll actually be travelling 61.9mph.  The better size would be 225/40/17's.
LanceS13 is offline   Reply With Quote
Old 02-25-2002, 09:36 AM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
of course, the ride will be more rough.
sykikchimp is offline   Reply With Quote
Old 02-25-2002, 09:39 AM   #4
sykikchimp
WOW addicted
sykikchimp's Avatar
heres a quick question:
Stock tire size is 195/60r15  Optional handleing package had 205/60r15.
Since the tire 205/60R15 would have a greater circumference, did nissan create a different speedo gear for that package?
Old 02-25-2002, 09:49 AM   #5
LanceS13
AutoX Junkie
I thought the 205's only came on the rear.  If that's the case, then  there'd be no reason  to  b/c the  speedo reads the  front tires.
Old 02-25-2002, 09:49 AM   #6
black0ut
Why would the ride be rougher with 225/40R17s? Thanks for the responses guys!
...contact me...
Old 02-25-2002, 09:51 AM   #7
LanceS13
AutoX Junkie
Less sidewall to absorb bumps.  However, that's also less sidewall to flex.   Less sidewall  flex means  better handling.  It's all a big trade-off.
Old 02-25-2002, 10:14 AM   #8
sykikchimp
WOW addicted
sykikchimp's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from LanceS13 on 11:49 am on Feb. 25, 2002
</td></tr></table><span id='postcolor'>
Only on the Rear??? Why would they do that? &nbsp;And I thought Our speedo read off the tranny not the wheels??
Old 02-25-2002, 11:30 AM   #9
LanceS13
AutoX Junkie
I don't know, I thought I heard that somewhere. &nbsp;
And maybe it does read the tranny, but I don't recall seeing my speedo jump when I break traction in the rear and my revs rise. &nbsp;I could &nbsp;very possibly be wrong.
Old 02-25-2002, 12:26 PM   #10
MorganS13
MorganS13 is an unknown quantity at this point
i'm like 99% sure the 205/60-15s came on all 4 wheels. &nbsp;i originally had 195/60-15s on my car but when i replaced my tires a couple months ago i put on 205/60-15s. &nbsp;i just wanted a bigger footprint and it definitely gave me a little more stability and a better feel. &nbsp;i'm not sure how much the speedo would've been off but i find it hard to believe nissan would have 2 different speed sensors(??) to account for this slight difference... anyone know for sure?
MorganS13 is offline   Reply With Quote
Old 02-25-2002, 12:29 PM   #11
LanceS13
AutoX Junkie
The difference between the two sizes is 1.2mph at 60mph...not much. &nbsp;I doubt they had two different sensors to accomodate for that small of a difference.
Old 02-25-2002, 04:13 PM   #12
AmericanSilvia
AmericanSilvia is an unknown quantity at this point
Nismo has new speedo sensor gears that will allow you to adjust the speed. Probably not for increments that small though! Check out CourtesyNissan.com for more info. That is where I saw them I think!
AmericanSilvia is offline   Reply With Quote
Old 02-25-2002, 04:14 PM   #13
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
Do we know if blackout has an s14 or s13?
IIRC, the 17&quot; upgrade for the s14 IS a 225/45/17. &nbsp;The correction factor from the stock 205/55/16 is way less than 1 mph.
So - if s13, trust Lance; if s14, the above should be correct.
HippoSleek is offline   Reply With Quote
Old 02-25-2002, 04:20 PM   #14
AmericanSilvia
Old 02-25-2002, 04:27 PM   #15
LanceS13
AutoX Junkie
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from HippoSleek on 5:14 pm on Feb. 25, 2002
IIRC, the 17&quot; upgrade for the s14 IS a 225/45/17. The correction factor from the stock 205/55/16 is way less than 1 mph.</td></tr></table><span id='postcolor'>
Do S14s have 17&quot; factory option?
I'm just going on my stock size of 195/60/15. &nbsp;If S14s came stock with 205/55/16s then the 225/45/17s would only be off by 0.2mph at 60mph...just like Mark said.
Old 02-26-2002, 07:49 AM   #16
HippoSleek
HippoSleek's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from LanceS13 on 2:27 pm on Feb. 25, 2002
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Do S14s have 17&quot; factory option?
I'm just going on my stock size of 195/60/15. If S14s came stock with 205/55/16s then the 225/45/17s would only be off by 0.2mph at 60mph...just like Mark said.</td></tr></table><span id='postcolor'>
No 17&quot; option, but the SE has the 205/55/16's. &nbsp;I'm not sure about the base, but I *think* the base s14 has the same 195/60/15 as the s13 SE.
Old 02-26-2002, 08:06 AM   #17
black0ut
It is an S13... thanks for all of the help guys :-) My new wheels will be coming in any time :-)
...contact me...
Old 02-26-2002, 10:26 AM   #18
Sick240
Sick240 is an unknown quantity at this point
btw, the speedo on my S13 runs off of either the tranny, or the rear wheels? all I know is when I light up my tires the speedo goes crazy, lates
Sick240 is offline   Reply With Quote
Old 02-26-2002, 11:39 AM   #19
LanceS13
AutoX Junkie
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Sick240 on 11:26 am on Feb. 26, 2002
btw, the speedo on my S13 runs off of either the tranny, or the rear wheels? all I know is when I light up my tires the speedo goes crazy, lates</td></tr></table><span id='postcolor'>
I guess I was paying more attention to the tach than the speedo then. &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Old 02-26-2002, 01:37 PM   #20
JeffNJ
JeffNJ is an unknown quantity at this point
I beg to differ on this point. I think the speedo reads the rear wheels. The next time it's raining, punch your accelerator with far more gas than you know is appropriate. This will, inevitably, make your rear wheels spin out like mad, and even though you're standing still, your speedometer won't seem to think so.
I mean, at least that's how the S13 is.
(Edited by JeffNJ at 3:38 pm on Feb. 26, 2002)
JeffNJ is offline   Reply With Quote
Old 02-26-2002, 02:09 PM   #21
LanceS13
AutoX Junkie
Like I said...I could &nbsp;be &nbsp;wrong.
Read Jeff...gosh. <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Old 02-26-2002, 02:40 PM   #22
sykikchimp
WOW addicted
sykikchimp's Avatar
Actually I KNOW &nbsp;the speedo is read from the Transmission. &nbsp;I remember this from my engine swap out when I blew my KA24e in my 90'
