Old 01-24-2010, 09:39 PM   #1
TriniTT
TriniTT is on the path to ruinTriniTT is on the path to ruin
98 kouki gauge cluster tach and odometer malfunction
Hey all, I'm having issues with the gauge cluster on my 98 kouki. The tachometer pegs out as soon as I start the car, and after it warms up a bit, it just bounces all over the place erratically. Also, the odometer isn't working; neither the trip nor the main odo. I've read that these are common problems, but I haven't discovered if there's a fix, or if I'm just supposed to replace it. Any help is greatly appreciated. Thanks!
TriniTT is offline   Reply With Quote
Old 01-25-2010, 08:00 AM   #2
vbgambini
vbgambini's Avatar
vbgambini is an unknown quantity at this point
I have the same issues with my cluster as well, but I have a 1JZ in it (could be the problem lol). Speedometer I got working with a speedo interface. But what my question is why why thermostat gauge will work for a few days then not work then work again? What can I check for? Thanks.
vbgambini is offline   Reply With Quote
