Work Gnosis HS201 19x10.5 ET+18 PCD 5x114.3
What is for sale:
Wheels: Work Gnosis HS201 19x10.5 +18. Tires: Toyo Proxes 4 plus Lip size: 3" Lug pattern: 5x114.3 They come with the Gnosis center caps and Work valve stem covers Not sure what disk they are, but they should be able to clear BBK's. Condition: Wheels: 7/10. Has rock chips from daily driving and the center caps are either dirty or fading. 1 wheel has a small bend on the back of it but it holds air just fine.(Refer to pictures) No leaks whatsoever. There are no curb rashes Tires: Tires have camber wear, but still has a little life on the inner tread left. Outer tire tread is still good and can be flipped. Although these tires aren't symmetrical, you can flip them and use them as summer only tires or track tires. (Refer to pics with penny test) Location: Lakewood Price: $1600 If you guy are interested or have any questions, please shoot me a text for faster response: 56two-618-5two76 Thanks for looking! |
| gnosis, work, work wheels, works |
