![]() Join Date: Oct 2003
GKTech In-stock & Ready to Ship
GKTECH 10 Blade SR20DET OEM Replacement Clutch Fan
- Direct replacement of the standard fan - Pulls 60% more air than the factory SR fan and pulls around 40% more air than the factory RB25 fan (a common upgrade)Nissan Silvia S13/240sx (SR20 & KA24 only) Nissan 180sx/240sx (SR20 & KA24 only) Nissan 200sx/240sx S14 (SR20 & KA24) Nissan 200sx S15 NOTE: Can not be used in conjunction with Nismo engine mounts as the mounts raise your motor approximately 20mm's which will make our fan hit your radiator shroud (our fan is 15mm larger in diameter than the factory fan). ![]() GKTECH S13 / 180SX / S14 / S15 Handbrake E-brake Extenders The GKTECH handbrake extenders are a direct replacement of your standard item and give more leverage which in turn helps lock up the rear brakes. Great for drift! ![]() ![]() GKTECH 365mm Front Lower Control Arms - S13 / S14 ![]() GKTECH S13 S14 40mm Rear Drop Knuckles ![]() ![]() GKTECH S13/180SX/S14/S15 40mm Front Roll Center Correction Kit ![]() ![]()
All pm's replied to.
GKTECH S13 S14 Wilwood S-chassis Hydraulic Handbrake Kit
Includes: Handbrake assembly Wilwood stand-alone 5/8" internal reservoir master 2 pot Nissan stand-alone SS braided line kit Dual caliper bracket - for Wilwood Calipers Wilwood Dynapro Dual piston calipers Wilwood Polymatrix A pads NOTE #2: Will NOT fit European delivered S-chassis' without the use of JDM or USDM calipers/rotors. Vehicle Compatibility: - Nissan 180sx - Nissan S13 Silvia - Nissan S14 200SX - Nissan S15 200SX - Nissan A31 Cefiro NOTE: designed to be used with standard S-chassis 9mm rear rotors ![]() ![]() ![]()
GKTECH Nissan S13 / 180sx Over the Radiator Oil Catch Can
