Buy this stuff to FIX my KA
IN LAKE CITY, Email for shipping prices! PICS avaiable. KA24DE: -6 Bunged oil pan A/C compressor S14 head w/ cams ( needs rebuilt ) Exhaust manifold w/ s14 O2 sensor and heat sheild TPS sensor knock sensor ( 2 ) Stock KA MAF ( will trade+ $ for Z32 MAF) #29 ECU SR20: fuel rail w/ FPR (2) sr trans dust plates Timing chain tensioner Cam retainers w/ hardware for both cams s14 Valve cover bolts T28 oil return tube S13: center console instrument panel with working switches driver/passenger power window switch w/ door handle driver side headlight cover green relays. Last edited by Shouldahadav8; 05-01-2012 at 04:34 PM.. |
Knock sensor is the same for nearly almost all 90's nissans up to 98 I think. I do have a sub harness somewhere, if I find the harness you can have it for free.
10 picked up, 20 shipped 10 picked up , 20 shipped |
#6 | |
Never used this pan I found it on a spare motor, pretty sure its bunged for a/c comp. the injectors are not in the rail but they are bagged and very clean. |
thanks for the pics.
looks to me that the oil pan wont work with an a/c compressor... what do you want for the sr injectors and do the mirrors come with the switch for the interior?
I know the car had ice-cold working AC when the motor with that pan was pulled....it had a huge rubber hose hanging with a bolt and clamp sealing it shut...LOL , but you could be right.
I dont have the switch, the mirrors came with my car as spares almost 4 years ago. the PO bought them because they shined more than the stocks. Just make an offer on the mirrors, Im asking $100 for the injectors with rail and stock FPR shipped. |
