I can't get my markers, fog lights, taillights, or any interior lights to shut off in my 89 240sx. It started after I put in a new stereo and changed my alternator. I'm so confused on why this is happening and the only way to shut them off is do disconnect the battery. Please help
Did you have any luck with that? I changed my jdm kouki tails to usdm and my running lights won't shut off? Going to check fuses, harness soon. I also have to disconnect the battery lol never had this problem.
Its not a fuse. It was something u tapped for power check your splices and check the factory service manual wiring diagram for the circuits you messed with.
Sent from my SGH-I747 using Tapatalk |
