#782 |
Issue with latest batch of S13 fronts
We've recently discovered that with our most recent batch of S13 front bearings, the factory without our knowledge used a different snap ring than previous productions, causing the fronts not to spin. With this discovery, the factory admitted their mistake and has shipped us replacement snap rings that are arriving shortly. We also have 2 videos (step 1 to remove and step 2 to put on) for the new snap ring here:
https://drive.google.com/drive/folde...Ft?usp=sharing We can new snap rings to any customers who have been affected.
240SX 5 Lug Wheel Hub/Bearings Conversions |
#785 |
I had the same issue. Use snap ring pliers but turn them horizontally, so that the pliers are level with the back of the hub and apply inward pressure towards the snap ring. Best way I found to get em off!
#787 |
We are out of stock due to the snap ring issue. We are working on replacing all the snap rings with the correct one and as soon as we do that we will make the front hubs available again!
#788 |
![]() Join Date: Nov 2009
I emailed yall, I unfortunately am one of the few that ordered a front pair with the incorrect snap ring. I would like to get the correct snap rings asap so I can finally get the car back down on the ground. Many thanks in advance!
#789 |
No problem, if you emailed us we'll send you the new snap ring.
#790 |
These are back in stock FYI
#791 |
![]() Join Date: Mar 2009
What's your recommended torque for the s13 front hub nut? I've heard the spec in the FSM can be too tight or too loose on aftermarket hubs because the range is so broad. Curious what you recommend for yours.
#794 |
We have limited stock still available. We are almost out of fronts. Then we will be out of stock for about a month.
#796 | |
![]() Join Date: Dec 2010
![]() Feedback Score: 39 reviews
I used fsm spec for reference, saw the range and used a number right in the middle. Been on these hubs for about 5 years now and no issues with lots of spirited driving and two track events. Sent from my iPhone using Tapatalk
![]() IG - allen.kerose |
#797 |
I bought s14 front hubs.
I need to replace OEM Studs with ARP extended studs for my wheel set up What ARP extended studs work with the front hubs? Sent from my iPhone using Tapatalk |
#798 |
We don't officially recommend or support any ARP studs any longer, but we've been told that customers have used:
100-7715 for fronts 100-7708 for rears
#800 |
Since we don't know who you are, please contact customer service with your question and info
#802 | |
More should be available early July.
#804 |
What's your name so I can look it up?
#807 | |
It is a dot com of the same name (fuelpumps)
#810 |
Hello, we do not allow pickup. All the pricing information should be on our web site.
