17x9 +20
how would this fit front/back on a s13? the car has a coilover set up, but thats about it. would i have to do alot of rolling, camber, stretching etc.? i tried searching but didnt find anything for this specific size. thanks alot guys.
Ghost of Zilvia past
![]() Join Date: Sep 2003
They'll stick past the fenders. an 8.5 with that offset would be perfect with a little camber, but that width and offset is better suited to an S14.
Pull the fenders and run lots of camber with stretched tires and they'll look great. Make them fit. ![]() |
![]() Join Date: Jun 2003
Ez to fit.
Please put 215/40s on the front tires unless you would like to run more camber than what dousan said. Rear would need to roll the fenders, front as well. No pull. |
#8 | |
![]() Join Date: Apr 2002
89 S13 hatch/////98 Subaru 2.5RS |
![]() Join Date: Feb 2004
I run 17x9 +10 front and +20 rear. 245s all around.
Rear fit so easily I am embarassed I rolled and flared the fenders. I'm running -2.8* camber which will probably be reduced to -2.5ish* eventually. Front required a lot of work: fenders are ghetto-flared, rolled, seams are hammered flat, harnesses are rerouted, fenderwells had to be sledged. I had no choice but to run the car higher because I actually use the car's cornering capabilities and would run out of clearance (on the fender arch and on the fenderwell also) far too early. |
