#13471 | |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
https://www.ebay.com/itm/SILVIA-S14-...cAAOSwNOJawnVS |
#13473 | |
![]() Join Date: Dec 2010
![]() Feedback Score: 39 reviews
Thanks guys ![]() ![]() Sent from my iPhone using Tapatalk
![]() IG - allen.kerose |
#13474 |
![]() Join Date: Nov 2009
Trader Rating: (18)
Any body know model of these volks
Volks https://imgur.com/gallery/mmvzDCS |
#13475 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
#13476 |
Trader Rating: (18)
@dorkidori i spent some time searching but only found one other picture online. If i remember correct it was stated as volks mesh. As far as the ones you found, looks similar to it. Spokes reach to bolts on one model, other model is shorter. I have no idea. So just trying to find the model on them. I think they are 26 bolts, too. I have to double count. If someone has more info, i would appreciate it, thanks.
#13477 | |
http://wheelflip.com/listing/259/vol...7x8-25-5x1143/ probably called volk evo III |
#13482 | |
Are these even legal in Florida with the reverse lights being red? Last edited by kcswiz; 11-10-2019 at 09:24 PM.. |
#13483 |
anyone know what would be the new cross reference to these grommet screw from Nissan as the one that are for s13 are "discontinued" but im dam sure Nissan gotta still remake them for use with their newer vehicles.
https://www.nissanpartsdeal.com/part...281-00153.html. This one apparently I need another 4 on top (72814F in the picture in the link), they are the 2 outer ones on each side and not the 2 center ones on that center panel windshield moulding. The grommet hole on these ones are the larger rectangular one and not small square shaped... I tried just goin to a regular autopart store and they didn't have a single one that had the rectangular shape lol... all small square!!! Based on lookin at the picture... I THOUGHT this grommet in the below link would have been the same since this one wasn't discontinued and they use the same screw and its for mounting the same windshield lower moulding panel... but apparently this is the SMALLER square ones!!! https://www.nissanpartsdeal.com/part...281-00691.html (these ones don't fit the holes and is labeled 72814E) This is a pic of the grommets I need and they are a rectangular shaped grommet hole and not the smaller square shape one https://ibb.co/Rg6s71M https://ibb.co/wpmzhm6 my last resort is just to plug weld those holes to make them fit the smaller square ones that the generic autopart store sells (same size as the small square OEM nissan grommet screws at the dealership) but that's stupid and extra work that shouldn't be needed to get 4 god dam grommet screws in LOL... so hopefully one of you fellow zilvians can help a brotha out. Thank yous |
#13484 | |
Insta: AllenSunnyD |
#13488 | |
#13489 |
update... apparently you can buy those replacement cowl grommet screws from RHD Japan as I guess they actually get them straight from Nissan Japan dealership themselves... go figure American Nissan Dealerships wont do this for you lol
#13492 | |
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
https://www.ebay.com/itm/Nissan-Skyl...-/123561918134 |
#13493 |
what oneline made were whole tail light sets, not covers. came in both zenki/chuki and kouki style. it was a plastic piece, just like these covers, then two round red reflectors and square corner bit, they all screw into that plastic thing.
zenki/chuki ones below ![]() ![]() ![]() the ones you're asking about - these probably weren't made by a big known brand. even on minkara you can't find any pics with brand of these stated in description, only "unknown brand" ![]() you could try to make these by yourself. doesnt look too hard |
#13494 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
OneLine made TAIL LIGHT REPLACEMENTS for the 180sx zenki/chuki and 180sx kouki models. OneLine ALSO made TAIL LIGHT COVERS for the OE 180sx kouki models. The replacements were full units that used OEM mounting holes, but they didnt have an internal molded cover. the backsides were completely exposed. they used a single bulb in the center of each lense that had a circular soft padded aluminum cover to prevent light from being seen in the center, it only illuminated the outside of the red lenses to give them the look of skyline tails when lit. the outer housing had fitment issues due to being slightly larger than the tail light recess area. the outside body of the lights was made from molded plastic. the insides were all hand assembled using epoxy cement and screws. The OneLine tail light covers have been replicated over and over in Japan since their introduction. They are still easily had on YAJ for like $75-$100 i believe. You will most likely NEVER get your hands on a set of OneLine tail light replacements as they are almost impossible to be had in Japan. I was bidding on a set for the 180sx zenki/chuki models that popped up (they were BRAND NEW too). i put $1200 on the auction, i was outbid in the last 10 minutes and the auction went up to $1500 by the time it was over. I am looking into replicating OneLine tails (as i have INSANELY detailed photos of exactly how the lights were made and put together), but yeah... thats a ways away from actually coming to light. |
#13495 |
Can someone ID this bumper? It seems like its a lip on a Navan bumper, but which lip? But it also seems "Bigger" than a Navan bumper which leads me to think its an aftermarket.
Any help is appreciated! ![]() |
#13498 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
I reproduce the S14 PACS Zenki valances and will hopefully have the S14 kouki versions + front bumper available next year. |
#13500 |
I have these front and rear seats currently in my s14. Came with the car. Anyone know what these came out of? The door card pictured is what I assume was the factory print/material.
https://imgur.com/gallery/RyllbbZ |
| 300zx, axles, body kit, bumper, die misinformation!, identify, j30, rare, search, what is this?, z32 |
