Old 06-02-2012, 12:35 PM   #1
ez8s13sr
ez8s13sr is an unknown quantity at this point
SR wont start with maf plugged in
need some help on my sr... my car wont work with the MAF plugged in. it runs fine without but wont go pass 3000rpm.. if i start the car with it unplugged its ok but then if i plug the MAF in while its on it just starts to die... it wont even start if i try it with it plugged in(except for the first time when i moved my CAS around)... does anyone know what it could be? someone told me it could be a boost leak, my ecu is chipped, or maybe the wiring, idk... i also tested 3 different MAF's. and they came off of a sr20det that worked fine
ez8s13sr is offline   Reply With Quote
Old 06-02-2012, 12:41 PM   #2
90S13hatch_tony
90S13hatch_tony's Avatar
Trader Rating: (24)
90S13hatch_tony is an unknown quantity at this point
Feedback Score: 24 reviews
My sr did that but it turned out to be a crappy maf. Have you tried cleaning the mafs with maf cleaner? It does a million dollars worth of good
90S13hatch_tony is offline   Reply With Quote
