Old 08-06-2015, 09:47 PM   #1
S30boostin
S30boostin is an unknown quantity at this point
for you S14 with 94 production year
Has any of you come across difference in parts due to your production year? I've ran into an issue with my inner tie rods. I bought a set for the S14 and found that they are too long even with maxing out the outer tie rods, I am still on a ridiculous amounts of toe in. I have thought about ordering a set of inner tie rods for the S13 if they are the right length and thread pitch and I haven't had much luck searching this year. Any input would be appreciated.
S30boostin is offline   Reply With Quote
Old 08-10-2015, 07:44 PM   #2
S30boostin
Does anyone have any inpuy on this?
Old 08-11-2015, 07:14 AM   #3
onehundredoctane
onehundredoctane's Avatar
If S14 didn't work, S13 will.
/thread.
Old 08-11-2015, 07:56 AM   #4
NISR20MO
NISR20MO's Avatar
NISR20MO is an unknown quantity at this point
/thread.
S13 and S14 inner and outer tie rod thread pitch where they mate to one another is different. You would need full S13 inners and outers. Try Z32 inners with S14 outers, they are shorter than OEM S14 inners.
Maybe someone swapped knuckles and LCA's before you got the car and you have S13 stuff? The only S-Chassis sold as a 94 was the vert.
NISR20MO is offline   Reply With Quote
