Old 11-14-2015, 02:37 PM   #1
04BlueBeach
04BlueBeach is an unknown quantity at this point
Idler Sprocket threads won't hold a helicoil.
I need some opinions. When I bought the car there was a helicoil installed for the idler sprocket. I replaced a head gasket and had to replace it. Worked fine. Now I'm rebuilding the engine and am trying to put a new helicoil in. The problem is there isn't enough threads left in the head to hold the coil! Every time I try to torque the idler bolt down it pulls the coil right out. I even put a bunch of lock tight on the coil and let it dry. I don't want to replace the head because I just had $500 worth of work done on it. Do I have any other options? The only option I can see is taking it to the machine shop where I had the work done at and see if they can put a sleeve or something in. Its a 1997 240sx KA24DE.
Sent from my 0PJA2 using Tapatalk
04BlueBeach is offline   Reply With Quote
Old 11-14-2015, 03:16 PM   #2
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
Timesert oversize
DennisC is offline   Reply With Quote
Old 11-14-2015, 05:59 PM   #3
KAT-PWR
KAT-PWR's Avatar
Originally Posted by DennisC View Post
Timesert oversize
Nailed it
MRP Manufacturing
Old 11-14-2015, 09:21 PM   #4
04BlueBeach
Ahh thank you! I take it that is comes in a Kit?
