![]() Join Date: Mar 2010
Trader Rating: (34)
![]() Feedback Score: 34 reviews
Godspeed TD05 18G & TD06 20G Actuated Turbos!
- Direct bolt on to SR motors (Both S13 & S14) - Tested and proven plenty here on Zilvia TD05 18G Turbo Spec.
18G - $299.99 Picked Up / $330 Shipped 20G - $349.99 Picked Up / $380 Shipped Call / Text - 626-274-4414 18G 20G |
#3 | |
Trader Rating: (34)
installing it, you may have a different mounting plate but you would just take the plate off the gsp actuator as they are interchangeable. |
Trader Rating: (34)
18G is done on Godspeeds own Time attack car. GSP intake and exhaust Manifold, GSP exhaust.
20G is on stock motor with 620CC injectors. You mainly will just need upgraded injectors and a tune for this turbo. Would also recommend some rocker arm stoppers just in case. |
#8 | |
GSP = Godspeed Project correct?
#12 | |
Trader Rating: (34)
Dont know where you got this fact from but it is on multiple cars of GSPs. Dont see why they would use else wheres products as benefits in hp would minor in changes.
Yes Quote:
You would have good mid and top end power with the cams! |
![]() Join Date: Oct 2006
so how do these turbos perform with internal vs external gates. ive read alot that the 2871r style turbos dont like the internal gate a whole hell of a lot. my qustion is can i stay internaly gated and still get 310 down with out too much spike?
![]() Join Date: Jun 2011
so are these direct bolt on meaning i need no other parts? i have a redtop sr20det with the stock t25, manifold, downpipe, lines etc. just wondering if i can just take out the old t25 and this will bolt right in with no other parts
#15 | |
Trader Rating: (34)
Yes, this is direct bolt on. It will drop right in to a stock SR20 |
