Power FC D-Jetro Installation
I did some research but didn't get a clear answer I was looking for.
Just bought the S14 Zenki Power FC D-jetro with sensors. However It seems to be S15 ECU and it came with S14 Zenki covert harness. Because the box has sticker in Japanese that it's for S15 (414BN024) but in English sticker it says S14 93~96 (414BN019).
Well my engine and wiring harness is S14 Kouki and about to order new harness so it does not matter which model this Power FC is.
But I think Air temp sensor gets plug in to male plug on that convert harness which I assume I will have to get Zenki wiring harness to use Air temp sensor.
When I was browsing Apexi website, I think I read about for S15 motor, I will have to manually hook up the Air temp sensor wire to engine harness so I guess that's what it is.
Anyways, Can someone post picture of Air temp sensor/MAP sensor installed picture or link of somebody who did it?
Also, I prefer not to use convert harness if I can, has anyone installed on S15 SR20 or S14 Kouki SR20?
I have stock intake manifold unfortunately so limited options.
