Nismo Mounts vs Drift Freak Mounts
I bought a set of Drift Freak mounts for my KA-T and have only installed the Tranny one so far. I like it, but my daily stock KA needs a new set of motor mounts too.
I know Drift Freaks are poly but apparently the stud placement reduces vibration. Theyre also cheaper than Nismos. Which would be the better set (motor mounts and tranny mount) for my application? Is Nismo worth the extra cost in my case? |
#3 | |
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
Clearly you haven't driven a car with DriftFreaq mounts installed on it properly. Ripzsaur, Just get the Driftfreaq mounts and be done with it. It's perfect for the street and very capable at the track as well. |
![]() Join Date: Feb 2012
Trader Rating: (31)
Drift freaq mounts are the shit. I bought mine in 2011 and have put ~60k miles on them. Still going strong and will be using them in my new chassis. They sit the engine lower too, which helped a lot with my CD009 swap.
Sent from my Galaxy Note 10+ using Tapatalk |
#6 | |
How is the vibration? And lower does sound nice, would make pulling the trans easier. How about oil pan clearence and stuff like that, any issues? |
#8 | |
Trader Rating: (31)
#12 | |
Trader Rating: (31)
![]() Join Date: May 2019
Man yall are crazy.... the mounts arent bad, just stiffer then factory/oem. A huge diffrence? No but some more vibration. Enough to pick it up in some trim panel rattles, n can feel it personally. Maybe im more sensitive to it then yall.. op askd for opinions on them, i gave mine. Doesnt mean im wrong for sharing my experience
#14 | |
You're an insufferable poser, that's why. |
#16 | |
That is, you pose. Poser. |
