Old 12-24-2008, 09:05 PM   #1
traxx07
Trader Rating: (63)
traxx07 is an unknown quantity at this point
Feedback Score: 63 reviews
SR20DET Not Starting
It cranks and has a orange spark.... any ideas?
S13 Redtop in a 90 SOHC Shell.
traxx07 is offline   Reply With Quote
Old 12-24-2008, 09:29 PM   #2
Sileighty_85
Sileighty_85's Avatar
What? an orange spark??
Elaborate, need more information
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-24-2008, 09:32 PM   #3
PinkPanther
PinkPanther's Avatar
PinkPanther is an unknown quantity at this point
Send a message via AIM to PinkPanther
have you checked fuel, timing, battery voltage?
PinkPanther is offline   Reply With Quote
Old 12-24-2008, 09:35 PM   #4
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
Orange spark means low spark. Thats why it wont start. Look up symptoms for orange spark in google. Its something electrical though more than likely.
duffman1278 is offline   Reply With Quote
Old 12-28-2008, 04:36 PM   #5
traxx07
Trader Rating: (63)
Ok, change fuel pump still the same but when I put fuel through the throttle body it will start and stay on..... other than that it wont start. Any ideas?
No more orange spark... all white but still nothing.
New ECU. Z32 Filter....LMK
Old 12-28-2008, 05:07 PM   #6
traxx07
Trader Rating: (63)
Here is a Video of what Im talking about.... and no there is no chicken in the background its the damn car!
Not Starting
Starting
Old 12-28-2008, 05:17 PM   #7
S14DB
AFC #1
S14DB's Avatar
I hope you are running MAP+IAT and not MAF.
Old 12-28-2008, 05:18 PM   #8
traxx07
Trader Rating: (63)
why?............
Old 12-28-2008, 05:45 PM   #9
S14DB
AFC #1
S14DB's Avatar
Cause you have some massive vacuum leaks without the charge pipes and intake hooked up.
Old 12-28-2008, 08:32 PM   #10
traxx07
Trader Rating: (63)
ok Mister Obvious.... anyone else?
Old 01-04-2009, 08:13 PM   #11
PinkPanther
are your belts ungodly loose or is it just an optical illusion?
Old 01-04-2009, 09:20 PM   #12
Sileighty_85
try starting it with the MAF hooked up just put the Throttle body Charge pipe on so you can also hookup the IACV and slap the MAF on the end of it and give it a shot
後輪駆動車1番
1986 SR86 - 200ish
