![]() Join Date: Aug 2008
240sx vert with sr20det alt issues
my car 1993 240sx vert with redtop sr20det
so i having power issues with alt or something ok about 6mo ago my car would start and go right to 13 to 14 volts and now when i start my car i have to rev my motor to get my volts over 12volts so it go to 13 or 14volts when driving it fluctuating from 10volt to 14volt and i can watch my lights flicker... i swapped alt still does it .. new lower harness still does it tested old alt on friends sr and auto zone and it perfect. I am at a lost on how to fix... any ideas or thoughts on this
Ripping up the Highway since 03 |
just throwing it out there what is the condition of your alternator belt? and were are you reading your voltage from? if you read directly off the alternator and its low then you know its that system. if its normal and it reads low at the batery that means you have crazy excessive draw from somewere after the alternator. possably a short
I have to rev once to get the charge up to 13 to 14 volts
