Old 04-30-2008, 08:32 AM   #1
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
No Ac?! Wth?
just wanted to know what i would need to put AC into an S14 that came no AC factory?
s13silady is offline   Reply With Quote
Old 04-30-2008, 10:10 AM   #2
CarloSR
CarloSR is making a name for him/her selfCarloSR is making a name for him/her selfCarloSR is making a name for him/her self
Compresor, evaporator, condensator, lines, harness, a/c ducts, a/c panel, etc. etc.. too much parts involved, too much work involved.
Didn't know that there was a USDM S14 model that came with no a/c.
CarloSR is offline   Reply With Quote
Old 04-30-2008, 09:17 PM   #3
got boost??
got boost??'s Avatar
got boost?? has a spectacular aura aboutgot boost?? has a spectacular aura aboutgot boost?? has a spectacular aura aboutgot boost?? has a spectacular aura aboutgot boost?? has a spectacular aura aboutgot boost?? has a spectacular aura aboutgot boost?? has a spectacular aura about
i didnt either?? mine is a 95 base and has ac
got boost?? is offline   Reply With Quote
Old 04-30-2008, 09:19 PM   #4
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
serei has the ac setup locally
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 04-30-2008, 09:56 PM   #5
s13silady
s13silady's Avatar
s14
aahh gotta love serei... lol. what doesnt he have?
but ya.. appearantly it came as an option for base model... but it has power windows.
Old 05-03-2008, 06:01 PM   #6
got boost??
thats fuckin weird
Old 05-03-2008, 09:15 PM   #7
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
You get fullty loaded base models then base models that have no options. Heh. The harness should be there, just unplugged and capped off.
In search of a Zenki S14 right side (passenger) fender and straight hood that are rust free.
Pacman is offline   Reply With Quote
Old 05-05-2008, 10:45 AM   #8
s14in215
s14in215 is an unknown quantity at this point
You need evaporator compressor condenser liquid lines high side lines pressure switch expansion valve. It shouldn't be too hard the vents should be there from the heater I don't think you need to take the dash off either for the evaporator. Good luck
s14in215 is offline   Reply With Quote
Old 06-11-2008, 06:26 AM   #9
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
Going to thread jack for a sec.....ANYONE know where the expantion valve is located? (S14 BTW) What will it entail to get to the part and replace?? THANKS!
And that is wierd...modern cars without A/C...pish, my 79' Datsun 280ZX had A/C!!!
The Chad is offline   Reply With Quote
Old 06-11-2008, 09:01 AM   #10
projectRDM
projectRDM's Avatar
Expansion valve is located within the evaporator case. Pull the case out from behind the glovebox (drop the glovebox and frame, four bolts secure the case) and slide it out. You'll see the valve inside.
a LOT of new cars don't come with A/C, cars sold up North don't have it as much since the summers aren't as hot. I used to do A/C work for two summers, we had a lot of cars come in from Maine, New Hampshire, etc. and installed full kits since they never had it OE equipped. A lot of work trucks come without it too, we did Silverados every day that were sold in base W/T form, not even a radio, antenna, or speakers, much less A/C.
FORMERLY R240NA
Old 06-11-2008, 11:31 AM   #11
The Chad
The Chad's Avatar
Project RDM: I believe you are quite possibly the most car savvy human being I have ever known. You have helped me with just about every problem I have ever had!! Thanks so much man!!
And yeah, you are right, I forgot about northern cars not having A/C...makes sense. I guess I'm just spoled by my A/C and radio
Old 06-11-2008, 11:56 AM   #12
S14DB
AFC #1
S14DB's Avatar
AC, power door locks, Cruise Control, Power Mirrors were optional on the S14. Power Windows are standard.
Are the holes drilled? I wonder how prewired it is for the AC.
Old 06-11-2008, 12:03 PM   #13
projectRDM
projectRDM's Avatar
Fully prewired, holes are drilled in the firewall. If you don't have A/C there's rubbers plug that seal the firewall.
FORMERLY R240NA
Old 07-04-2008, 11:29 AM   #14
The Chad
The Chad's Avatar
[quote=projectRDM;2102848]Expansion valve is located within the evaporator case. Pull the case out from behind the glovebox (drop the glovebox and frame, four bolts secure the case) and slide it out. You'll see the valve inside.
I got the evap case slid out, but I can't get enough slack on the A/C line to maneuver around the box to actually remove the box completely to get to the Valve. I do see the valve but I just can't get to any of the connections.
Any ideas on how to get some more slack on the A/C line?? I did contemplate removing the fitting from the engine bay side...but seems a bit brash, and a pain (i don't have the proper sized wrenches )
Old 07-04-2008, 10:10 PM   #15
The Chad
The Chad's Avatar
Anyone??? Please???
Old 07-04-2008, 10:14 PM   #16
white92_s13
white92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nice
[quote=The Chad;2155552]
you have to evap the system, and then undo the lines from the wirewall then the box comes out of the car.
if your a/c system still has freon in it, then take it and have it vacuum out and emptied. then take the lines off.
box comes out easy. i did one on my s13, its pretty simple
white92_s13 is offline   Reply With Quote
Old 07-05-2008, 02:11 PM   #17
projectRDM
projectRDM's Avatar
Originally Posted by The Chad View Post
Anyone??? Please???
The lines have to be removed to get it out. They're a 17/19mm for the smaller one, 30/32mm on the larger one IIRC.
FORMERLY R240NA
Old 07-08-2008, 12:47 PM   #18
The Chad
The Chad's Avatar
Thanks guys, I figured it was that, i'm allways looking for an easy way out though . The system had a leake so i don't need to purge the system as it is allready empty. Thanks again!
Old 07-09-2008, 03:03 PM   #19
952jz240sxr
952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices
just get a diff car.. ac is to expensive especially if you didnt have it to begin with
952jz240sxr is offline   Reply With Quote
Old 07-13-2008, 12:36 AM   #20
The Chad
The Chad's Avatar
I did have A/C that's why i'm replacing broken/bad parts to make it work again... cool?
