2003 IS300 - Single Turbo 2JZGTE w/ built R154 (5speed)
Hate to do this but stuff has come up and gotta be a grown up. IF INTERESTED CONTACT ME DIRECTLY WILL NOT RESPOND ON HERE. 847 772 6675.
2003 Lexus IS300 - Single turbo 2JZGTE w/ a fully built manual (5 speed) R154 transmission. Currently makes about 530 WHP on E85 needs an extra pump and can make over 600 to the wheels, lots of work done and tuned by Sound Performance, LLC. Chassis has 195k miles (no rust!) prior west coast car. Engine has been fully refreshed with new gaskets and seals (including head gasket), ARP head-studs, ACL rod bearings and new pistons rings. Head was decked and block was machined. All paperwork in hand. Precision 6266 single turbo Oem Supra coil on plug coil packs Radium fuel rail (-6 feed/return) ID1000 injectors Ecumasters flex fuel sensor Aeromotive fuel filter Aeromotive FPR Walboro 450 fuel pump PHR Racing fuel hanger Mishimoto radiator Driftmotion lightweight pulleys Fluidampr harmonic balancer Chase bays power steering reservoir Chase bays ABS delete Driveshaftshop steel one piece drive shaft Driftmotion DBW delete ECUMaster EMU standalone Karl Long wiring harness/patch harness w/ sensors (clt,ait,boost pressure,afr, fuel pressure) R154 fully built Marlin Crawler/Driftmotion Competition Stage 4 clutch/lightweight flywheel Megan motor mounts Driftmotion trans mount Figs rack bushings ECUMasters bluetooth CAN adapter Fortune Auto 500 coilovers All braided hose/AN fittings Tuned by sound performance Clean title in hand $18000 or best offer. I have LOTS more in the car. My loss your gain. IF INTERESTED CONTACT ME DIRECTLY WILL NOT RESPOND ON HERE. 847 772 6675. |
| 2jz, 2jzgte, lexus, supra, toyota |
