![]() Join Date: Jul 2007
Trader Rating: (106)
VQ35de swap/fwd to rwd conversion parts, pics added!
I have a complete vq35 motorset with a rodknock that I am parting out. I have everything but the clutch and flywheel. The engine was running and without a CEL when it was pulled.
COMPLETE FWD engine to RWD conversion parts set (mechanical only). -upper/lower oil pan -complete inake mani -water pipe -headers -cats If other mechanical parts are necessary please LMK and I will include them in the set. All parts will have all the electrical switches and sensors that are originally attached to the parts unless otherwise noted. This does not include the flywheel, clutch, wiring harness, ecu, o2 sensors, or trans. '03 350z longblock with rodknock Engine ran when removed from the car, has spun bearing. '04 350z 6-speed trans Trans has less than 10,000mi on it. The ears on the tailhousing to mount the shifter bracket to have been broken. Other than that un-damaged. Comes with the shifter itself and the damaged shifter bracket. '04 350z engine wiring harness w/gas pedal Complete harness, un-damaged. Comes with the small sub-harness that goes to the coilpacks on the passenger's side of the engine. A couple wires on the subharness have been rubbed through, but nothing un-fixeable. '04 350z ecu Good working condition. Not pictured. '04 350z underdash harness with bcm & nats One connector has been damaged. BCM not pictured. This also includes the engine room harness and the main battery harness. The engine room harness has been cut where it goes up to the headlight area, that wiring is un-necessary on a swap. The battery terminal end of the battery harness is also damaged. AEM intake piping w/bypass valve I also have and AEM intake for '03-'04 350z but the filter is missing. Brand new OE 350z radiator hoses and oil filters Hoses: Oil filters: '04 350z a/c compressor Super low mileage, stored indoors. EVERYTHING IS SOLD!!! Last edited by racepar1; 04-06-2009 at 10:33 PM.. |
