#61 | |
![]() Join Date: Dec 2008
Trader Rating: (71)
![]() Feedback Score: 71 reviews
the 1st one is jus regular led come in variety of colors 2nd are the high power smd's only come in blue or white tips: only use white led for the middle one cause buttons have blue n red coating....if you use red or blue its gonna be dim depends wat color is use. no modding needed they fit perfect...only thing is removing them is a b**tch like when the polarities are backward cause this are polarized leds/smds lmk if ya got any ?? oh get the 3mm |
#63 |
![]() Join Date: Dec 2003
maaaaaad props!!!!! if we still had rep i would hook you up lol. its good to see someone in norcal is doing shit right.
looks proper im in the process of striping mine and goin painless, but girl problem are causing serious delays. Im taking pics as i go alont tho so youll see what i come up with soon. congrats again on the start up
S.P.P.S. Member #00**CoUpe LOve** Member #00 |
#64 |
![]() Join Date: Feb 2009
damn you .. now imma have to do mine with i get home.. and pressure wash half of california streets from inside of the bay.. you should relocate the PS resi next
Need parts or your car sprayed, PM me for Details
#65 | |
Trader Rating: (71)
time and patient all it is! yea this is just my temporary set-up not 100% done just wanted to make sure the engine fired up before finalizing everything! yea i will be relocating the ps reservoir thinkin about nxt to the clutch reserv! will be using the s13 ps reserv |
#66 |
time and patient all it is! yea this is just my temporary set-up not 100% done just wanted to make sure the engine fired up before finalizing everything! yea i will be relocating the ps reservoir thinkin about nxt to the clutch reserv! will be using the s13 ps reserv[/quote]
yeah thats where im putting mine too ..
#68 |
where did you put your charcoal canister?[/quote] duuno where imma put it yet .. im goin to get new vaccum lines and go from there..
#75 |
nice work my friend. that looks sooo clean
and the DCC and your cluster looks bitchin. i wish i had the patience and the cash to do all that.. i dont. and i dont have another car anyway. downtime is no good at the moment :P congrats on the great work mann |
#76 |
I have a couple questions for the OP, since im in the middle of my full tuck right now aswell. Other then that it looks good. Im tucking the P/s resi up by the clutch resi, aswell as getting an inline fuel filter to clean up the lines from the fuel rail going on top of the manifold to the filter and tucking it behind the manifold on the firewall.
1. when you installed the dcs, did you use all the sensors and b/s or did you wire it into the factory usdm harness? (i guess it would be like having the digital system just without the auto climate controll?) 2. did you think about keeping the 2 fuse boxes before you just eliminated them and relocated everything to the glove box? ....me and a friend have found that the fuse boxes themselves can stay where they are just by flipping them upside down and putting them on the underside of the metal from where there at from the factory locations. Now that im tupped though im going to have to make a custom mounting slot on my passenger side but my drivers side will still use that slot from the factory which the fuse boxes use to keep them in place. of course i will have to secure the lids since they will be mounted completely upside down now but it should work out fine. I just got my car back to my garage but i can get pictures of what im talking about and how im going to make mine work if you need an example. Im still a bit far away from completing it but its coming along. Also keep in mind the only way someone could possibly pull off the tuck using the same spots for the fuse box i'am using is if they are N/A or have a v mount intercooler setup, because all the other ways i could think of you have to cut holes in the metal where i would be mounting my fuse boxes. |
#77 | ||
#78 | |
Trader Rating: (71)
#79 | |
oOooOoOoOoOoO, i understand sometimes i gotta do things the hardway aswell. |
#82 |
![]() Join Date: Jun 2003
Trader Rating: (129)
this pic isn't a great example, but i relocated my entire harness and fuseboxes into my glovebox. now the only wires that are in the bay are my headlight harnesses and engine wiring. now i have a crate overflowing with wire i cut out.
i need to redo it cleaner and more "baller". |
#83 |
O know tjis is kinda taking it back a bit but do you think the NEO4's will work in the DCC? Im just wondering because I was hoping for more options than white and blue, but I will go white if I have to.
Product Listing - CAR
#84 | ||
Trader Rating: (71)
#86 |
Daym dude that looks sick! You have to tell me your secret. How do you keep track of all the little screws and where everything goes?! I was thinking of getting like little platic bags and labeling everything. Or taking alot of pictures in case I forget where something goes or how it was hooked up previously. I envy you, man. Good job, really.
#87 | |
Trader Rating: (71)
thanks bud! |
#88 |
![]() Join Date: Mar 2008
great thread and taking time to help other people out...good stuff
your tuck is incredible, if my chassis wasnt a rustbucket you would have motivated me to undertake this task with this thread. now you may have motivated me to start looking for a clean coupe shell to do this in, im tired of the hatch... |
#89 |
![]() Join Date: Sep 2008
Dam this confuses me so much. I dont understand how your supposed to keep track of every wire. So.... if im doing a track build. where i wont need any of the smog equipment.. or AC, or anything that makes the car more confurtable.. can i take alot of the sensors off ?? im still trying ti figure this all out.
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
#90 | |
Trader Rating: (71)
goodluck |
