Does nissan 200sx s13 have a oem " stock " sway bar?
Hello !
Currently i have a sway bar wich previous owner have installed ( unknown brand blue color ) My question is, does the 200sx s13 come with a stock or oem sway bar ? Sorry for this noob question.. Also, how do u go on removing it ? Thank you ! |
#3 | |
Also, this is my first car. I just want to learn, i tried googling found no results and its why i asking here. so yeah,i need to know, like really need to know if car comes with oem sway bar or not its about keeping my license plates. Welcome to Norway !!!! |
![]() From that same FSM I linked you to in the other thread about the thermostat. They label it a stabilizer bar but it can be called an antisway bar as well. If you want to get your car to factory spec for this inspection, AND have a way to prove this is how it came from the factory if challenged, I highly suggest you sit down and read through that document. It really will answer all of these little questions for you. http://www.eatsleepboost.lt/files/ma...air_manual.pdf There is a link to it again. |
