Ok i have Car A which is a totaled 1993 240sx Convertible with working A/C and heater. I have Car B which is a stripped 1990 240sx fastback/hatchback. When i say stripped i mean it has no motor, transmission, a/c components, heater components no dash no seats nothing. Just a stripped track intended shell.
So my question, can i transfer everything from Car A to Car B and will it all work? I mainly mean all the a/c stuff and heater? |
Look at the firewall to find out if the holes are in the same area. If yes, the a/c and the heater parts will swap over.
Do need the Factory Service Manual? Click here. |
![]() Join Date: Aug 2009
If you don't know it will leak when you start disconnecting ac parts, then you should leave everything alone. Compressor is to compress. Stay in school. Learn how to read. Read a book. Learn on how stuff work.
