Sr20dt Hydraulic Lifters
I pulled all my lifters out to get machined one of them wouldn't come so I said screw it and got it milled, Now lifter is not even close to coming out it won't even budge how should I go about getting them out?
And as well I can't bleed them idk if I'm not doing something right but I have it in a glass of oil and I'm trying to push an allen wrench in the little hole and compress it but superman himself couldn't push these lifters down, Im i doing something wrong?? |
#2 | |
![]() Join Date: Feb 2005
As for the one that won't come out, have you tried putting a rag around it and using pliers? |
![]() Join Date: Dec 2004
Trader Rating: (58)
Why are you machining lifters?
Or are you taking them out just get the head machined Use a pair of lyers grip the tip of th elifter as low as you can, and then twist/wiggle it out. It'll come. Or even spray some penetrate oil/wd40 around it, may be some coked oil. You can even use a 'strong' paperclip to push down on the HLA to bleed it. It must be 100% submerged when you do this. If you have any that are just plain stuck, I'd suggest getting ALL new, and then also verifying/making sure your oil pump/system works as well. They can collapse/not work, and if so, order ones for a B15 sentra, as they are of the upgraded design (00+ roller rocker engine sr20)
