Autox Technician
![]() Join Date: Dec 2001
Still dominating Street Mod
Finally got to run at a REAL autocross!! Having missed the first New England Regional (NER) points event, I'm starting the season at a handicap. Made up for it this weekend by showing how much both the car and the driver have improved!!!
On saturday there was a non- points event, where I was 2 seconds ahead of the next place car in my class. Then on Sunday i repeated the same class result, and also managed to get myself to the 11th spot on the overall PAX list (in NER that's a big accomplishment)!!! The car handled BEAUTIFULLY. Ran the T25 at 8.5psi and it was already too much power for the short course on the NHIS parking lot. I probably could've gotten more power to the ground with a quaife diff, as the VLSD was NOT distributing the power as well as I would have liked. Having 4 deg or so (by eyeball measurement) doesn't help much either... i have to fix that before the next event, so I can start climbing higher into the PAX listing. The D2 coilovers ROCKED. Almost nil body roll, and I had front and rear wheel lift through some corners (gonna try to fix that by extending the mounts and lowering the spring perches a bit). VIDEO (please "save target as") in DiVX format: http://www.engr.uconn.edu/~corrales/...ox/NER_event1/ Runs of both my co-driver and I are up there. My co-driver is only a "sophomore" autocrosser, so he's still learning the tricks of the trade. I'm using the video to help show him what's wrong with his line, etc. I can't wait 'till I'm eligible to be an instructor ![]() HaLo!! Get your ass down here for an event!! All the other 240's in the area are DEADed. I was the only one running on Sunday!
from Canada, eh!
![]() Join Date: Sep 2001
Hey Ace!! I know I need to go down there!! But my car isn't ready yet... Had so many problems recently, I might get it this week.
I still haven't received my tires, decided to go with Yokohama A032R for contingency and other issues. I am a bit short for money right now and I do have 2 events in may... But i do what to slip by in may, maybe june!! Don't worry, I will pass by!
-> HaLo Race Car: '98 E36 BMW M3 Daily Driver: '08 Fiji Blue Honda Civic Si SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
from Canada, eh!
Damn, you're really quick on that course!!! I'm not even close to that... I think!
Autox Technician
I still had problems getting on the throttle early out of corners. The combination of a weak VLSD and excessive rear camber hurt my acceleration. I REALLY wanted to drop into the 32's on that course (my best was a 33.24 on my last run)... and I think a better set up rear end plus me not screwing up the inside turnaround would've done it. I think the ideal time would have actually been a mid 31 for a street mod car. Getting closer to that
I'm wondering what to replace my victoracers with next, too. I think I might stagger and get some z32 TT wheels for the back. Run 265 V700's in back and 245's in front, although Ideally I'd just run the 255 wide hoosiers on all 4 corners ![]()
from Canada, eh!
I honestly have to say that you are one quick panda ...
![]() I look forward to seeing you run with my bare eyes. I'm a lone 240sx driver too here, and I'm not as quick as that... I'm starting my spphomore year too! I still have a lot to learn. I can't hardly wait for the season to start. You guys are lucky to start in April... We start in may... and the season doesn't fully kick in before july. I'm seeing that the D2 coilovers look very stiff.. What spring rates are you running on them? How would you compare them to your previous setup... I was thinking about them too... But I have to make a decision... Coilovers or more suspension goodies (anti-sway bars, nismo powerbrace, ladder bars, roll bar)...
Autox Technician
the D2's i'm running have 9kg springs in front and 7kg springs in back. they're paired up with whiteline sways and STBs front and rear. i also have adjustable RUCAs and TC rods. poly bushings should be in before the next event
![]() Compared to my last setup, these are unfathomably better!!! I go through the slalom sections like they're nothing, as weight transfer happens so fast! The car is much more predictable going from full throttle to full braking back to full throttle (as is seen coming off the inside turn-around). All in all, they're DEFINITELY worth the money! Anyways... Is it normal for my front tire to lift during hard cornering?? And my co-driver drives like a pansy. i need to fix that....
![]() Join Date: Jul 2003
how would you compare the D2's to Tein HE's? I picked up a set of HE's for 1000, so I couldnt pass up on that. I'm new to autox, but I'm looking to get into it heavy this and next season. My current set up is
91 Hicas SR, all bolt ons, no cams, t25, 11-12psi (might go to HKS actuator instead of Greddy EBC), HE's, Tein Tension and tierods. I might be getting a set of 16x7 +36 and 16x8 +36 rims..ideas on tires? I was thinking Azenis or BFG KD since I'll still be daily driving.
Drew |
#9 | |
Autox Technician
Between the tires listed, go with Azenis. Ultimately, you might want to look into getting a set of race wheels to put R compound tires on.
from Canada, eh!
Dammit PJ!! You tempt me... espacially that another group-buy of those are going around... I currently have AGX+GC setup with 425/375 (7.5/6.7) springs... I like my setup, but I don't "love" it either... I would love more travel on my shocks. But I still need sway bars. I'm having a friend in Japan source me some used Cusco adjustables.. Then I'll think about coilovers and one Bride Brix.
![]() Your car doesn't have any body roll... it's incredible. And you seem to be able to control it at high revs. I wish I could do that. ![]()
#11 | ||
Autox Technician
If you can get down here for an event before the GB is over you can compare my car's ride to yours.Quote:
The high RPM control was something I really wanted to work on over winter. I'm running a WRX BOV now that's been recirc'ed almost directly into the intake pipe, so there's very little recirculation hose. The BOV comes right off the hot pipe so that it's venting where the most pressure is coming from, hopefully reciculating ALL of the air the compressor needs to draw in. It seems to work great so far. The big deal now is to fix the rear camber and maybe get a Quaife diff. I don't really trust the KAAZ too much, as I don't want to ruin the neutral handling of the car or make it more unpredictable by a diff that doesn't engage/ disengage smoothly.
from Canada, eh!
True on the diff... I'll try getting an S15 diff on my side. I don't want a clutch-type differential.
I'll try to make it down on May 29-30 event in Devens. I really can't before that, unfortunately. I'll be bringing down my R tires and maybe my GF to have fun watching. She's taking up Auto-X this year with her Supra. ![]()
from Canada, eh!
Oh, and by the way, I'm happy to see that the new 240sx is rolling. I heard bad things from my friend Matt (Krash on B15Sentra.net) happen to your diff going to the last event.
#14 | |
Autox Technician
from Canada, eh!
Cars... Can't live with them can't live without them.
![]() I had all my problems with Master cylinders... had to replace clutch and brake and I was so dumb i put back in another 240sx one when I got the Q45 brake upgrade. I also have to install Axxis Ultimates... Can't wait to try them out... I actually can't wait to get my car back from the body shop. ![]()
![]() Join Date: Mar 2002
good god PJ, I didnt see a single oversteer/understeer in all of your runs...
what tires did you use again? azenis? the panda looks like its running on railroad track... I doubt my t3 super 60 will be responsive as your t25... we'll see..
![]() ==>>TGL GARAGE<<==.. RIP! S13 coupe KA-T @ 0.5 Bar = SOLD! A31 Cefiro + SR = Current |
#17 |
from Canada, eh!
He's running V700 Victoracers IIRC. Great tires.
#18 | |
Autox Technician
The understeer/ oversteer was mostly fixed the previous day during a non-points event through camber settings. The rear could still be a bit better, but for the most part, I understeered once on run 5 braking too late going into the inside turnaround, and had a little throttle- on oversteer at the finish on a few runs. My co-driver is too pansy to push the car hard enough to break traction Actually, I bet I could've pushed a bit more. The only time it got really hairy was on run 6 going to the outer part of the track on the right hand side, and it wasn't even that bad. I'll try to push a little harder next time I LOVE this car!!!!!
#19 |
![]() Join Date: Sep 2002
damn Ace sounds like you had alot of fun! I wish our Autocrosses were larger than they are last time I went to a local one we got 3 runs.
but eh still fun sounds like your getting the suspension and the driver dialed in right keep up tehe good work!
Keeping it Godzira bishes. So I murdered another turbo |
#20 |
nice, great job!! the last few events ive done has gone well... a first, second, and a third in DSP thus far. i need to switch suspensions, hopefully to GC's and Koni's. the RSR Race springs are good, just not competative. and im still learning the Victo racers, they are quite different than the Azenis i ran all last year. and third, i need to get that HLSD put in. i should be able to cut a second or two with that diff!! ill actually be able to power out of corners finally! other than that, i dont have much else i can do is DSP. i may do a cage, and i may still do an ECU and some head work. that way ill still be legal for DSP.
![]() HighTach Motorsports |
#21 |
Autox Technician
Nice job! The victoracers at least don't have as steep of a learning curve as the hoosiers... but JMCN and I had to take out an instructor a few times to really learn the "ropes".
ANyways, results from the weekend are up! http://www.ner.org/soloII/2004schedsolo.html check out the April 17 and 18 events! I'm 11th in PAX and RAW overall. I was also the fastest "street" car in raw times, and only 1 non-street car was faster in PAX :P On the overall PAX standings I beat a few National Champs ![]()
#22 | |
![]() Join Date: Oct 2001
#23 | |
Autox Technician
#24 |
STX national competetor Tom Hoppe uses modified Tein HA's... they did an article on him and his car in grassroots once. he was at the Michelin March of Dimes Autocross that was like 3 weeks ago, the same event i won DSP in...
#25 |
man all this talk about autocrosses... cant wait till weekend..
we (tamscc.org) are having an autocross this weekend... it'll be a fast and long one (around 1~2miles long, thanks to the abandoned landing strip). you guys should caravan down here and autocross ;p
#26 |
They allow "aftermarket" forced induction into your street mod class? All the events I've been to, any time you touch boost whether it's upping boost, adding turbo, upgrading turbo, etc, you are automatically place into the modified class.
#27 | |
Autox Technician
Street Mod = unlimited engine modification using a long block within the same Manufacturer.
#28 |
![]() Join Date: Jul 2002
Car looks good, Ace. I noticed some rear wheel hop in the corners. Might want to play with your rear rebound settings.
Allen Delta Region SCCA SM 1990 240SX SR20DET |
#29 | |
Autox Technician
#30 |
from Canada, eh!
Ace, do you know any cheap hotels in your area? My GF and I are coming down for the may 29-30th event...
