#121 | |
if your aiming for a really responsive motor, I recommend a GTX3076 in a .64AR, big power then go with the GTX3576 in a .64 or .73 AR Great build so far, watched the Dyno run at PSI vid and it sounds so good, keep up the outstanding work, but may I suggest some attention to brakes ![]() maybe a set of 30mm Z brakes to a 350Z rotor for the fronts and full z32 rear brakes, would help keep the car from doing sad things in tight places
Two-Tone owner#011509-Lightly Modded
#122 |
buying the EFR 7670 tonight! i think it will be the right decision..hopefully!
#123 | |
![]() Join Date: Jun 2011
IG:@AAPARKAH #ThisIsTheWolf |
#125 |
It's between the PTE 5862 and the s358..
s358 -11 blade GTX58mm compressor wheel ( quicker spool ) -360 HD thrust pad upgrade ( quicker spool) -quick spool turbine wheel -.83ar twinscroll hotside main difference will be journal vs ball bearing... what should i do!! and will one hit my power goal easier than the other? i'm expecting around 15psi around 3500rpms, and want to run around 20-30 psi max. I'm aiming for 500whp and also on pump gas and water/meth. |
#126 |
never mind, i decided on the EFR 7670 with 1.05 exhaust housing.
Seems like the best option for the response/power i'm looking for. |
#128 |
ahh well now I'm kind of stuck what i want..
Either the EFR with the .92 housing or the 1.05 housing. The .92 housing is internally castigated, and i would just be welding that shut and running two 38mm tial wastegates.. or just get the 1.05 and maybe buy a quick spool valve to make up for the difference in price..? the .92 is about $300 more... and i wouldn't even be using the internal wastgate.. ANYWAYS, i got my new kit fitted up!! ![]() One of my sponsor's, TEAM SDMF doing work on the JZ chase! ![]() |
#129 |
2 years later i have the car back guys!! this thread is coming back to life!!!
