![]() Join Date: Jul 2016
Hello everyone,
I have an s13 transmission on my s14. There is no place for me to put a crank position sensor on the bellhousing. I know that this sensor is not needed for engine operation and am trying to get rid of the trouble code. How do I bypass the sensor? Can I use a resistor? Also, I deleted my egr and want to get rid of that code too. Can I use a resistor for that? Thanks, Evan |
![]() Join Date: May 2006
Measure, drill and tap hole to make it work on the bell housing. but that's me and i would of done it when i have the tranny out.
18g and 20g turbo users click on me #/f/tech-talk/261219-18g-20g-turbo-users.html
I would have done it when the tranny was out too. The issue is that I bought the car swapped. I just want to make sure there is no other way before I go about pulling the motor out / dropping the transmission. Do you know if the signal from the sensor is constant or does it vary with rpm? Also do you think that this code would fail emissions?
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
You don't. Pull the trans out and follow this guide and do it right.
http://forums.nicoclub.com/s13-ka24d...p-t384931.html |
| cel, crank position sensor, ecu, egr, trouble code |
