Old 12-21-2013, 02:44 AM   #1
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
1jz vvti compression check
so, my car is burning oil and it's driving me crazy.. it came down to the valve seals or the piston rings..
The car puffs oil out after the end of revs, and on decel, even the slightest blip of the throttle would puff out a little smoke. Its defiantly oil.
anyways i did a compression check tonight and came across 120psi on all cylinders.. i thought it was rather low, and though maybe the compression tester just reads low.. BUT i did add oil to one of the cylinders to see if it would make a difference. I repeated the test on the cylinder i added oil into and the tester read much higher, like 180psi.
i didn't continue on the rest of the pistons because of anger, but by doing this test, are my rings fried?
all the cylinders are consistent at 120psi.
at 1:30 you can see the smoke on decel, while its on the dyno.
S14 1JZ DYNO RUN by John Reed - YouTube
the car did 310whp with stock turbo at 15psi.. which confuses me if the rings are so shot, IF SHOT..?
Drift team page
www.facebook.com/savageimpression
Options13 is offline   Reply With Quote
Old 12-21-2013, 07:45 AM   #2
hashim
hashim is an unknown quantity at this point
rings, more than likely, the oil helped seal the CC and thats why your compression went up, if it was valves it would still read low.....just my thoughts
hashim is offline   Reply With Quote
Old 12-21-2013, 09:25 AM   #3
Jesus_lopez405
Jesus_lopez405's Avatar
Jesus_lopez405 is an unknown quantity at this point
My money on rings !! Have you checked our spark plugs ?
Jesus_lopez405 is offline   Reply With Quote
Old 12-21-2013, 09:36 AM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Rings done...did you check the minimum acceptable compression for 1JZs? Nissan is roughly 125psi.
CLICK HERE!!!
Old 12-21-2013, 11:18 AM   #5
Options13
Options13's Avatar
Trader Rating: (43)
damn, it's just crazy because the motor had very low miles when i got it, and was super clean.. i guess its a good sign all the cylinders are consistent though.
Drift team page
Old 01-09-2014, 11:54 AM   #6
S13project
S13project's Avatar
Had similar issue with my SR. Car was spewing smoke on decel. Turned out to be turbo going bad.
Old 01-09-2014, 11:28 PM   #7
Options13
Options13's Avatar
Trader Rating: (43)
I already changed out the turbo, and it still doing the exact same thing.
Drift team page
Old 01-09-2014, 11:41 PM   #8
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
A leakdown test should confirm that it's the rings. Adding oil and seeing the number jump is a pretty good indicator of rings not sealing.
Old 01-10-2014, 12:39 AM   #9
Options13
Options13's Avatar
Trader Rating: (43)
With my compression being as low as it is, shouldn't i be blowing oil out my valve cover and oil dip stick tube? I should be getting a shit load of blowby.. but i'm not? hmm..
very confusing, and i don't exactly know where to rent a leak down tester, and been too lazy to make one..but i may end up doing it.
Drift team page
Old 01-10-2014, 05:47 PM   #10
sterlinge
sterlinge's Avatar
sterlinge is an unknown quantity at this point
Do you have a restrictor for the feed line? I would use one. You could also have a pinched drain line. If you dont have blow by I doubt its the rings. Maybe the valve seals. A leakdown test will tell you the condition.
sterlinge is offline   Reply With Quote
Old 01-11-2014, 01:41 AM   #11
Options13
Options13's Avatar
Trader Rating: (43)
yup, have a restrictor, the tomei turbo came with one, and the drain line isn't pinched. I'm just gonna attempt a leak down test and see whats going on. i'll keep you guys updated.
Drift team page
Old 01-11-2014, 06:33 AM   #12
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
Your compression is low but not so far gone as to cause the dipstick to blow out. My VVTI 1j is between 155 and 160 across the board.
The sr i got rid of for this engine would pop the dipstick out but it has over 30% of blow bye on all of the cylinders.
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 01-11-2014, 01:31 PM   #13
FutureFab
Trader Rating: (32)
FutureFab is an unknown quantity at this point
Feedback Score: 32 reviews
I had the same issue. Turns out it was the turbo.
Did yours smoke with stock turbo and tomei turbo?
futurefabrication.com
FutureFab is offline   Reply With Quote
Old 01-11-2014, 02:51 PM   #14
brndck
brndck's Avatar
Reading. It comes in handy on the internets.
