Old 07-13-2008, 02:21 PM   #1
nissanman22
nissanman22's Avatar
nissanman22 has made poor choicesnissanman22 has made poor choicesnissanman22 has made poor choicesnissanman22 has made poor choicesnissanman22 has made poor choicesnissanman22 has made poor choicesnissanman22 has made poor choices
tire stretch gurus
i will be purchasing some 17 inch rims that are 9 inch wide in the front and ten inches wide in the back.. what is the hottest profile size to get 40 or 45 and what about the witdh .. should it be streched or not.. what an apporpriate size tire. i have a comeplet body kit all around that isnt really aggressive its the origin lab type 2 i believe..
i have no clue what to do so an help would be gretaly appreciaetd.
yo
nissanman22 is offline   Reply With Quote
Old 07-13-2008, 02:33 PM   #2
adrians_s13
adrians_s13's Avatar
what's the offset? You do know the reason why people stretch tires for right? It's for fender clearance...
and sidewall size depends on what width you wanna go with.
@adrianfromthecastle
adrians_s13 is offline   Reply With Quote
Old 07-13-2008, 03:03 PM   #3
nissanman22
17 on all four with stock fendsers in the front and a slight pull in the back.
yo
Old 07-13-2008, 03:13 PM   #4
brian m
brian m's Avatar
brian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond repute
Here's some good reading
#/f/showthread.php?t=136032
brian m is offline   Reply With Quote
Old 07-14-2008, 05:10 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
225/45 for stock diameter with a low offset 9j. For higher offset and you have some clearance, 245/40 17s and itll be square.
CLICK HERE!!!
Old 07-14-2008, 08:28 PM   #6
Landers
Landers has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond repute
run like 215/40 in the front and 225/40 out back If you have decent offsets, but really you need to read that thread.
d-faction.com
Landers is offline   Reply With Quote
