Old 11-28-2010, 09:31 AM   #1
MidwestMyriad
MidwestMyriad's Avatar
MidwestMyriad is making a name for him/her selfMidwestMyriad is making a name for him/her self
KA HELP!! Running Issues....out of State need help now!!!
I have a 1991 240sx, the car was driven 150 miles to my parents for thanksgiving, then sat for three days. When I started the car, everything was fine, drove about 8 miles to the store, car sat for about 2 hours. Came back outside and car started fine. Then as I was driving home the dash lights started to dim as well as the headlights. Then the radio started shutting off and the car began to sputter and cutout. When the lights were turned off the hesitation would lessen. Got the car limped home and while it was sitting in the driveway it eventually died. Now the car will only start with a jump and after about 5-10 minutes of idling it cuts out again....Battery is an interstate that is less than 2 years old. Haven't replaced the alternator yet, is this the problem? 75A fuse for alt. is still good. IF the problem is the alternator, will a new battery at least carry enough amps to get me home(assuming i dont use the headlights or radio etc.)
@MMyriad
MidwestMyriad is offline   Reply With Quote
Old 11-28-2010, 09:36 AM   #2
Sileighty_85
Sileighty_85's Avatar
probably the alternator
Jump the car, After jumping the car pull off the Neg terminal, if the engine dies then the alt is dead and needs to be replaced.
Or if you got a Multimeter, you can check the voltage the alt is putting out at the battery, should be around or greater than 13.5V
Or take off the Alt and take it to Autozone and have them test it
Buy a new alternator, battery probably wont last 150miles
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-28-2010, 09:39 AM   #3
MidwestMyriad
Yeah didnt think so......UPDATE....buzzing coming from the fuse box?
@MMyriad
Old 11-28-2010, 10:19 AM   #4
S14DB
AFC #1
S14DB's Avatar
More then likely relays from low voltage.
Old 11-28-2010, 10:21 AM   #5
MidwestMyriad
WTF does that mean?
@MMyriad
Old 11-28-2010, 10:21 AM   #6
MidwestMyriad
I just need to get it to stay running long enough to get home.
@MMyriad
Old 11-28-2010, 10:24 AM   #7
holemilk00
holemilk00's Avatar
Trader Rating: (33)
holemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the rough
Feedback Score: 33 reviews
1000% Alternator.
I had a cool signature
holemilk00 is offline   Reply With Quote
Old 11-28-2010, 10:25 AM   #8
holemilk00
holemilk00's Avatar
Trader Rating: (33)
WTF does that mean?
hes saying that a relay needs a certain level of voltage, but since your alt is gone they aren't getting that voltage so they are trying to engage and buzzing because they don't have the voltage to do so.
Old 11-28-2010, 10:26 AM   #9
holemilk00
holemilk00's Avatar
Trader Rating: (33)
And a fully charged battery will only get you going for about 30mins to an hour tops, depending on what all you have on the car, if the car has a lot of power options, then less than that.
Old 11-28-2010, 11:22 AM   #10
S14DB
AFC #1
S14DB's Avatar
Exactly, they are clicking on and off making the buzzing noise.
Take the alt off and take it down to the store for a free test.
