![]() Join Date: Jun 2007
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
240SX S13 s14 maxima PARTS part out sr20det ka24de coilover tein tomei turbogodzilla
gauges
tools: Matco snap-on mac or something on the high end is recommended 30in or 40in toolbox the wider box you have the better Motorcycle gear, MED or LRG helmet, 2 piece zip together racing suit sz40-44, armor Last edited by Hashiriya415; 03-25-2015 at 03:27 AM.. |
![]() Join Date: Oct 2004
The rear subframe is that for S13? If so what does it include when you install? I might need a subframe swap... LMK.... Local
Turn and Burn!
$55 Brand new Marshal 100PSI fuel gauge, made in Cali. 1/8in NPT port in back
$300 S13. Rear Lower control arm, has 1000miles of use, just some paint chips here and there but great condition bushings are still like new very solid. To fit S14 you need to order different size bolt that goes into the upright $20ea Center heater vent, great condition no damage to anything. $40 side mount intercooler, can be used with any car as long as you make the brackets and piping, bracket on side is included. Does not come with couplers shown $10 brake master cylinder off S13, paint starting to come off because when I removed it the brk fluid spilled over it. $20ea or 2 for $30. Tie rod boots, fits S13 and S14 also many other cars. Comes with 2 long zip ties $10 4 way wrench 7/8in, 3/4 (19mm) 13/16in 11/16in |
