![]() Join Date: Apr 2007
if you let the seatbelt go back, you can unplug the wire to the motor and it will stay in the back postion.
![]() Join Date: Nov 2006
Take off the plastic trim that goes under the quarter glasses. Shut the doors with the key on, then unplug the motor. And your done. IF you can not do that then i dunno
92 vert converted 5speed and other little things
![]() Join Date: Dec 2008
Trader Rating: (71)
![]() Feedback Score: 71 reviews
do this: close all doors then turn the key to the "ON" position wait for the belts to go fully to the back and then unplug the connectors from the motor both sides if want both of them not to move ever....turn ignition off and youll be good to go..... another one is to get s14 front seat belts and install it on ur car...will need modding on panels unless you get 180sx panels... |
Had this same problem not long ago...apparently behind the rear side trim you can manually rotate the motor with a hex key...you have to remember to unplug the controller though..
Trader Rating: (79)
![]() Feedback Score: 79 reviews
what i meant by they dont go back at all is that when i turn my car on they dont go back they stay forward.....so i cant unplug the wire until they go back...
Trader Rating: (71)
wooopsss..mis-read your post......then check motor connections and computer connections and i cant recall if there is a fuse for the power seat belt....you can also do what 8869muscle said....with the panels installed there should be round covering you can take that out and you should be able to get the hex without taking panels out...
![]() Join Date: Dec 2002
The rear quarter panel has a small round plug that pops off to access the motor. Use an M5 hex key and manually turn the motor to move the belt mechanism. Then take it to a dealer and have it warrantied.
#13 | |
OR.. Our cars have a lifetime warranty on seat belts. If you go to a Nissan service center at a dealership, they will inspect it and order new motors, tracks for FREEEEEEEE!!! but I did option one.
![]() Join Date: Aug 2008
Another option is the S14 seatbelt conversion. I did that to my S13 after the thing tried to kill me when I had to open the door to reach a keypad for my gated community.
+1 for this man. im gonna go to the nissan dealership and get my driver side rail replaced. they have been locked in the back position for as long as i can remember.
http://www.d3m14n.com/ |
#17 |
...you mean at the dealer?
I went first thing in the a.m. and had them inspect it... took like 2-3 hours. then they told me they couldn't tell if it was the motor or the track so they were ordering both from Japan and the would be there in a couple weeks... in the meantime, some dickhead pig gave me a no seatbelt ticket even though I had the hip belt on...$100, and i heard it triples if you get a second. So thats why I just pulled it back and unplugged the brain.
#18 | |
ahh ok, so i can just show up at one of the dealership service center and tell them that mine arent working.. and etc.
http://silaudrey.blogspot.com/ |
