Vg30dett ecu
I recently picked up a jdm vg30dett. I opened up the ecu and found no eprom in there so I am guessing this is a 16bit ecu (newer engine?). There is also no secondary board in the ecu that is connected to the main board by a ribbon strip. The engine has run off of this ecu in the past, or so I have been told but the ecu looks to have once had "n/a" written on it in sharpie but it has been worn off too much to clearly read it.
I was just wondering if any one knows if there are any distinguishable differences between the tt and n/a ecu? Thanks for your time, Brent. |
![]() Join Date: Mar 2009
Nistune states you can use a z32 na/tt auto or manual for you S1 Rb so I'm guessing no..
Trade my Rb25 for some wheels. Buy my Sc300. Last edited by josephin510; 01-18-2012 at 05:04 PM.. |
#3 | |
& gimme part number on the front cover.
