![]() Join Date: Sep 2005
![]() ![]() Feedback Score: 6 reviews
ALL PRICES DO NOT INCLUDE SHIPPING
EMAIL IF YOU WOULD LIKE A SHIPPING QUOTE ALL ITEMS ARE O.B.O. 1. Apex'I S-AFCII in the "limited edition" black. -$old 2. HKS Adjustable Wastegate Actuator Works for S13 T25/GT2871 Ran this for about 6months on my S13. Works like a charm. Adjustable up to 14psi. If you want higher boost you need to incorporate either an EBC or MBC. Base boost pressure is 10-11psi. Perfect for those still running a SMIC. The mounting plate has been drilled( 1 extra hole ) to make this actuator adaptable to the ever popular GT2871R. -$55 3. SPL Sub-Frame Collars Ran these on my S13 for about a year. Help reduce wheel-hop and improve responsivness of your suspension. In pretty good shape, the bottom collars have a few dings in them due to how horribly shot my factory bushings were, but I dont think it should have any affect on their use. -$40 4. Mishimoto Electric 12" Radiator Fan -$old 5. Stock SR20DET Camshafts Factory cams out of my S13 Blacktop SR20. Rebuilding my engine from top to bottom, so no need for these anymore. Comes with cam gears. -$70? Not really sure what these are worth 6. S13 KA24DE Factory Intake Pipe Good condition, its just been sitting in my basement since early 2005. Just want it out of here. -$5 7. S13 KA24DE Factory Airbox Good condition. Just like the pipe, its just been sitting in my basement and is taking up space. Has one of the lower resonator pipe things still attached to it. Might work for an SR20 setup as well, but I'm not sure on that, would think the hotpipe might get in the way? -$10 8. Snap-On 3/8" Torque Wrench Like New. Ive only used this a MAX of 6-7 times. Part Number: QD2R100 Adjustable from 20-100 ft/lb in .5ft/lb increments. Comes with 3/8" - 1/2" adapter, case, and certificate of calibration. -$180 retails for $259.00 from Snap-On As stated above, all items are OBO and prices do not include shipping. If you need an item shipped, you can reach me via PM or Email. [email protected] i check email 5-6times a day so that is your best bet. I'm located in southern York County, Pennsylvania. If interested I can meet you if you are somewhat local, say within 50 miles or so. Last edited by drifter_for_life06; 01-28-2009 at 11:03 AM.. |
From what I was told when i purchased the actuator....no it will not. If you look I believe that S14 and S15 T28 actuators have a bend in the rod, this one does not.
Hope that helps |
#8 | ||
460
