![]() Join Date: Nov 2010
The first pic you have the sway bar circled with a missing sway end link. The rod below is a tension rod I believe.
![]() Join Date: Jun 2003
Trader Rating: (129)
You are missing the sway bar end link. Also you have a LOT of rust in there. Don't bump threads every five minutes. It's annoying. Give us time to respond.
![]() Join Date: Oct 2012
Yeah you dont need front tension rods either you can just ditch those. Also look for your muffler bearing -- chances are you dont need it and it can save you a lot of weight, go ahead and remove that
