?95-240sx-ka24de-auto, rough idle when stopped in gear
I know there are a million threads about rough idles on here, but I have tried everything, and I would love to find an expert. The car continues to idle rough when under load and stopped. It idles great in neutral. I have also done all of the following:
Rebuilt engine New friction set in transmission New torque converter New tps New distributor and cap New plugs and wires New fuel pump New fuel regulator New fuel filter New injectors New alternator New power steering pump New idle air control valves New pcv valve New vacuum hoses New catalytic converter New oxygen sensors New engine mounts New transmission mounts Probably more that I am forgetting It also does not appear to be the brake booster. I have also looked at all the sensor values using an adaptor+free software, and they all appear to be in spec. I would love to hear some knowledgeable feedback! |
| Tags |
| automatic trans, ka24de, rough idle, s14 |
