Old 01-22-2007, 12:19 AM   #1
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
DIY: Fender Rolling / Flaring Tutorial for S13 240sx - w/ buckling resistance ;)
Since some of you liked my battery reloc write up so much, thought I'd whore it out and post my fender rolling one now that I've done a few more cars (tutorial is from Oct 2006) and have started tinkering w/ possible anti-buckling procedures (limited success depending on amount of flaring). Anti-buckling procedures are in second post (from Jan 2007). Don't mind the bluish tint camera - forgot to set it from manual settings -> automatic, oops! And keep in mind that each car has a different chance of buckling (some seem to buckle right as you roll, some take a pretty good flare before buckling, and others have ripples when flaring because of messed up inner fender lip).
Title: "We be rollin', patrollin'..."
So I dropped by to visit my buddies' local 240 shop today & decided I should roll and flare my fenders to prepare for upcoming modifications. There are numerous DIY articles and posts floating on the Internet, all with tid bits here & there, but all of them seem to be missing some info. What I will try to do is combine all that knowledge and put as much of it into one post as possible . I'll probably still miss a lot of info, but hopefully this will help some of you guys out there who want to run bigger tires/less negative camber with your crazy low offset & wide rims.
Note: Although it is possible to use the same method for the front fenders, it is more common to just "hammer" in the lip up front because of the flimsiness of the front fenders. This method has not been tried with the front fenders yet... This rolling tutorial is being performed on a '92 Nissan 240sx convertible.
Total Project Time:
- Approximately 2-3 hours for both rear fenders with taking pictures and comparing/aligning both sides. Took our sweet time (at least on one of the sides, haha) to make sure everything was going to plan.
Equipment:
- Ratchet set for loosening/tightening lug nuts (my stock lug nuts are 21mm)
- Towels/rags - something to clean the fenders and work area
- Eastwood fender roller
- Heat gun (I used the Chicago Electric Adjustable Heat Gun from Harbor Freight), a hair dryer could also work but will be slower
- Infrared Thermometer (not necessary, but highly recommended to prevent paint cracking)
Preparation:
- Put your car up on jack stands.
- Remove the wheels
Step 1: Clean your fenders
- Clean around the fender area and inside the wheel well behind the lip (this step is VERY important; you don't want any pebbles getting stuck inside your fenders and showing up when you roll!)
- Clean the fenders again just to be sure
Step 2: Attach the fender roller
- Use the supplied adapters and your stock lug nuts to attach the fender roller
- The orange knob in the middle of the arm adjusts the height of the roller. I had to change height frequently while rolling to get everywhere - the 240 fender isn't exactly a circle, but more of an oval.
- The knob by the roller head adjusts the angle of the head. I left it at the same angle my friend used (which is about 15-20 degrees from vertical).
- The long arm in front of the hub adjusts the distance between roller and the fender (counter-clockwise moves the roller closer). I adjusted the roller until it touched the fender. Rolled a bit. Then tightened a little more, approximately 1/2 - 1 turn each time.
Step 3: Heat up fender
- You will want to heat up the lip, edge, and all around the fender area you will be rolling. 120-140 degrees Fahrenheit is the recommended temperature, according to popular sources. If you don't have an infrared thermometer just make sure it's hot to the touch, but not to the point where your paint is boiling!
- Note: we rushed the driver side a bit, and had uneven fender temperatures (120 F backside, 100F front side). The passenger side was done with no cracking at all. This cracked the paint almost right away. So please take your time if you want to minimize paint cracking.
Step 4: Start rolling
- As stated above: I adjusted the roller until it touched the fender. Rolled a bit. Then tightened a little more, approximately 1/2 - 1 turn each time. You will need to apply force liberally, but not too much - if you hear paint cracking, slow down, loosen the roller, and check for damage.
- You can either roll the lip flat and stop, or continue adjusting the arm in front of the lug nuts to get flares. This all depends on your setup preferences.
- It is much easier to have a friend heat and monitor the fenders while rolling. Have him/her heat up the area surrounding where you are rolling and basically follow and lead you while you are rolling. We heated up about 1 foot beyond the fender lip to make sure the metal stays hot & malleable.
- Start rolling from the top of the wheel well and work your way toward front and rear progressively. As you get closer to the front and rear areas, there will be less room for the roller to move, so adjusting height is required. Also, you may need to use a little more force to "persuade" the lip into folding.
- When comparing both sides for evenness, look both behind and in front of the car to see how each side flares. When on the left side behind the car, look w/ the left eye. Try to position yourself in the same relative position on the right side of the car w/ the right eye. Looking from the front of the car and directly above the wheel well will offer more angles to compare both sides.
- Note: the driver side tends to buckle a lot easier than the passenger side when flaring because there is no gas tank equipment to reinforce the fender. Be very careful when working on the passenger side and make sure everything is heated correctly and not too much pressure is being applied. This has happened on both my coupe and my friends hatch. With the '92 240sx convertible, we did not experience the buckling problem, perhaps due to the extra bracing the vert has, or maybe we were just more careful/prepared this time around.
Step 5: Finish up
- Once everything is even, unbolt the roller, reattach your wheels, torque the wheels to factory spec, and enjoy your new found wheel well room!!!
brokeAs240sx is offline   Reply With Quote
Old 01-22-2007, 12:22 AM   #2
brokeAs240sx
Trader Rating: (40)
Preventing Buckling... well, most of it anyway .
If any of you have tried to roll/flare your fenders, you know what a bummer it is when the fender buckles (almost inevitable for most 240's). I was able to fix mine w/ some new toys from Eastwood - inflatable dent poppers/removers. It gets rid of half to most of the buckle. Not perfect, but much better than doing nothing.
These pumps can also possibly be used before/during rolling/flaring to help prevent buckling, or at least keeping it to a minimal. However, I have not yet tried using it as a buckling preventer/inhibitor.
Total Project Time:
- Approximately 20-30 minutes, taking your sweet *** time
Equipment:
- Ratchet Set (10mm & 14mm)
- Heat gun (I used the Chicago Electric Adjustable Heat Gun from Harbor Freight), a hair dryer could also work but will be slower - recommended but not required
- Inflatable Dent Remover/Poppers
Preparation:
- Locate buckle - say a final farewell to it.
Step 1: Remove Interior
- Remove your rear seat & rear quarter panels to allow access to the inside of the fender.
Step 2: Heat Up Fender
- Heating up the fenders (120-140 degrees as when rolling/flaring fenders) will help make the metal more maleable
Step 3: Pump and Sculpt
- Start pumping w/ either the large or small pump. It should pop the fender right out.
- Allow the fender to cool.
Step 4: Repeat and Alternate Pumps Used
- Deflate the pump.
- After the first time, some but not all of the buckle should be gone (depends on how badly you buckled the fender). "Heat-cycling" the fenders & pumping/popping it w/ the pump should start shaping the fender back to its original form. I did 3 cycles, which got rid of nearly all of the buckling. You can't really tell in the pictures, but a smaller less noticeable buckle is still there.
Step 5: Stuff It!
- When accessing the inside of the fender, you may have some foam cubes. You can reinsert and wedge these in between the fender and wheel well, which will help pop out some more of the remaining buckle. This isn't the professional way, but seems to work pretty well.
Step 6: Marvel at a Job Well Done
- YAY!
**** NOTE: I've unbuckled a few cars now, and it seems the fastback's buckle (depending on how bad it is), can possibly rebuckle after some driving. A possible solution to this is to insert something, such as foam sheets to help push against the fender once it's been unbuckled... think of it as sound deadening .
The coupe & other fastback done seem to have retained their shape after unbuckling for this past month.
Old 01-22-2007, 12:28 AM   #3
implayaz9
implayaz9's Avatar
implayaz9 is a well-known jackass
nice write up.. question. do u provide services to do this or? this is for people who dont have equipment.
implayaz9 is offline   Reply With Quote
Old 01-22-2007, 12:29 AM   #4
initial_drifter
initial_drifter's Avatar
initial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of light
Props for spending time to make a good write up!
initial_drifter is offline   Reply With Quote
Old 01-22-2007, 12:39 AM   #5
HyperTek
sweet.. the pimp my ride s13 huh!!!
Keep it Classy
Old 01-22-2007, 12:43 AM   #6
Flipzide
Flipzide's Avatar
Flipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfection
Great writeup! I'll be looking at this in the future.
Yea, I was gonna mention that as well.
D-Street.net | bcuison.wordpress.com
Flipzide is offline   Reply With Quote
Old 01-22-2007, 12:47 AM   #7
HyperTek
hhehe.. offtopic, but any new pics of how the car looks now?!?! lol
Keep it Classy
Old 01-22-2007, 12:49 AM   #8
kaboomwoom
kaboomwoom is an unknown quantity at this point
hey! its that s13 from PIMP MY RIDE!
kaboomwoom is offline   Reply With Quote
Old 02-08-2007, 12:53 AM   #9
coupelove626
coupelove626's Avatar
coupelove626 is an unknown quantity at this point
thanks for the post QV!!! u rock.
coupelove626 is offline   Reply With Quote
Old 02-08-2007, 01:11 AM   #10
McRussellPants
McRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond repute
your fender didn't buckle since you didn't pulled it up instead of out.
That adds no useable width.
if you try and lower your car the wheels won't be flush without rubbing to all hell.
people need to lay off the fender rollers, body hammers, paper and jackhandles all work better.
McRussellPants is offline   Reply With Quote
Old 02-08-2007, 01:16 AM   #11
McRussellPants
Also, Heat the inner skin when you do it. the outter skin is easy to shape, the inner skin pulling it in a weird direction is what buckles it, you need to stretch/rip the inner skin.
Also disconnect your rear shock. because it helps for some retarded reason, I think its because you can get a better angle on the roller.
Old 02-08-2007, 01:19 AM   #12
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
awesome write up
markyboi is offline   Reply With Quote
Old 02-08-2007, 01:25 AM   #13
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
I agree. Jackhandles work great. So do wooden baseball bats.
I did mine by leaving the wheels on. Jack the car up. Used wooden baseball bat to pry on fender while I pushed it into the tire. Adjust the ride height of the wheel to get the best prying position. I pryed on that tire pretty good and it never popped off the bead.
Picture.
Flybert is offline   Reply With Quote
Old 02-11-2007, 03:37 PM   #14
thepest
thepest's Avatar
thepest is on a distinguished road
Send a message via AIM to thepest
GOOD SHIT! Want to do mine? lol
thepest is offline   Reply With Quote
Old 02-11-2007, 03:37 PM   #15
thepest
thepest's Avatar
Old 02-11-2007, 04:37 PM   #16
mayco_86
mayco_86's Avatar
mayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfection
Hey I need my fenders pulled how much to do them.
mayco_86 is offline   Reply With Quote
Old 02-28-2007, 05:03 PM   #17
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I got my fenders rolled by brokeass. How I just need to save up for the wheels.
Jung918 is offline   Reply With Quote
Old 02-28-2007, 05:27 PM   #18
McRussellPants
Damn, so you're rolling SEs, and you found it nessicary to not only roll your fenders before you even got wheels but pull them as well.
so now, when you do get wheels, they'll be forever sunk or spaced because you did the roll before hand.
hahahahahahahahahaha.
Touche Zilvia, Touche!
Old 02-28-2007, 05:37 PM   #19
Jung918
Jung918's Avatar
I'm getting my car repainted next month so I wanted it done before then. That way the fenders can get smoothed out.
I'm not worried about the spacing. If the gap is too much, I'll get bigger tires. If the gap is not enough, then I'll roll it more.
Old 02-28-2007, 05:44 PM   #20
A Spec Products
A Spec Products's Avatar
A Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfection
Send a message via AIM to A Spec Products
Yeah, typically its not a good idea to roll fender before getting the wheels that will require them
Also, getting wheels before paint is also a good idea to work out fender clearance
I would've just hammered it flat versus pulling
A SPEC PRODUCTS CORP
AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more!
626.618.1100 x 103 / aim: aspectuan
Advertiser's Specials! Read / Give Feedback! Please Rate Us!
A Spec Products is offline   Reply With Quote
Old 02-28-2007, 06:05 PM   #21
hella_flushed
hella_flushed's Avatar
hella_flushed is on the path to ruinhella_flushed is on the path to ruin
are you getting your wheels before the repaint? if not, it kind of defeats the purpose of a paintjob if your gonna pull it even more afterwards. just a thought...
zilvia is wack now...
hella_flushed is offline   Reply With Quote
Old 02-28-2007, 06:21 PM   #22
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
Bigger TIRES? I await your 305/16/85's you're installing on your SE's to make up for that fender gap
high performance driveway photography
zenki s14---v8 fc rx7
my crappy flickr page (drift cars whoo)
Pank is offline   Reply With Quote
Old 02-28-2007, 06:27 PM   #23
nassin31spr
nassin31spr's Avatar
nassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to behold
Great write up. Ive been thinking about going to get my fenders rolled but now realize its something I can do my self. Thanks for all the great info.
nassin31spr is offline   Reply With Quote
Old 02-28-2007, 07:07 PM   #24
Jung918
Jung918's Avatar
If volks weren't so expensive I would have picked them up earlier.
Old 02-28-2007, 07:13 PM   #25
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Now lets throw on that HLSD. =]
SochBAT is offline   Reply With Quote
Old 02-28-2007, 07:21 PM   #26
Jung918
Jung918's Avatar
It's still in the fastback. Been too busy to take it out.
Old 02-28-2007, 07:52 PM   #27
drift into a curb
drift into a curb's Avatar
drift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond repute
It doesn't help if you drop the rear strut in most cases. That's only if you're car is too low and the roller wheel is only hitting the fender well and not the actual fender.
If you don't want the dent, you should consider not rolling it so high, maybe about only 1" to 1.5" high of the actual fender, so you decrease the area you're actually pulling. Also, don't get so angle happy. As someone pointed out, you're pushing the fender lip up, but not as much usable clearance.
Jung918 fenders are MAD ripply like mr. ripleys believe it or not. Tell brokeass to go a bit slower and work it over evenly. That reminds me of one of my first pulls and when I used a hammer to roll it.
And Yes, get wheels before the pull! People always want to pull but you should just roll your fenders first and then get your favorite wheels and test fit them to know how much you have to work.
Go big or go home!
drift into a curb is offline   Reply With Quote
Old 03-01-2007, 07:32 AM   #28
PBucch
PBucch's Avatar
PBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfection
Dude thats fucking gross!
might as well cut and mold in overfenders now 8o
section ef&ec changed my life
PBucch is offline   Reply With Quote
Old 03-01-2007, 07:48 AM   #29
boyou2
boyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura about
it's not very "round" no ??
boyou2 is offline   Reply With Quote
Old 03-01-2007, 07:48 AM   #30
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
hahah, dude posted pics of his roll/pull and gets made of fun of b/c its all wrong.
your car doesn't look like it needs paint. you should've got wheels before you pulled and painted.
slideways2004 is offline   Reply With Quote
