Metallic rubbing noise
Car has been sitting for quite a while due to vq35de swap being a pain. Take it out for a quick trip and I had a metallic rubbing sound coming from the passenger front wheel. Again it was just sitting and magically started. I didn't worry about it because I planned on doing 5 lug and z front brakes, thinking maybe the noise was due to those. Well I have changed those out and the noise is still there. Take the wheel off and turn the hub by hand and the noise is still there. The only thing I can think of to replace now is everything those bolt up to. That maybe it's all warped at this point. Anyone have any additional help here? S13 hatch btw
![]() Join Date: Jun 2005
Wheel Bearing?
Did you trim the backing plate/shield for the rotor? Or do you even have one installed? Could be rubbing the hub... ?
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 | |
Bearings were replaced with 5 lug setup and same issue after. Removed the dust shield today hoping that would fix the issue. I could call the noise more of a scraping. What I'd expect to hear if I had a warped rotor or something but they're new along with the hubs, bearings, and pads/ calipers
Sent from my SAMSUNG-SM-G870A using Tapatalk |
