z32 maf installation into sr20 black top
Just got a n62 maf, sr20 blacktop
wires are white,black, black/white, orange been looking at guides and arrcoding to the diagrams the orange and the black are the grounds. the white is the +12 volt and the white/black is the signal out. wired it according to the guide and it starts strong but when you rev it, it seems as though its dying. |
![]() Join Date: Nov 2010
z32 maf
looking with 2 humps up 3 humps down, from wire side. ~.5 signal, ground ground, 12v signal.
i connected everything correctly the black/white(12v), grounds orange to chassis and the black the the ground wire, and white(.5v). it will start but will sputter and then stall. for some reason if you take the chassis ground and touch it with the (.5v) it will idle perfectly but won't rev past 2.5k
