#31 | |
![]() Join Date: Jun 2007
Edited last post.
#33 |
Your "finished" section is incorrect. The radiator cap is a spring rated for x psi. Once it "burps" it should not suck air back in if the cap is functioning correctly. Any air that is in the system is not complete bled or is being introduced somewhere else in the system. The only logical place, assuming all hoses/fittings are air tight, is the head gasket. A leaking head gasket does not have to be mixing oil and water to be bad. It could have created a vein from cyl to coolant passage to leak hot gases into the cooling system. Again, the only easy answer to this is a leak down test or a hydrocarbon test as mentioned before. The OP said he did a leak down test and saw air bubbles coming into his radiator.
My SR20VET |
#34 |
Respectfully, the cap is not a factor- OP also has an open barb right under his radiator cap that should have a line connected to it going to the overflow reservoir... Between expansion/contraction of the coolant and revving the engine up & down, the system is going to "burp" out fluid and ingest air until he puts a hose on. Please watch the video and look where the fluid is coming out:
I am not sure if I posted the video correctly (at work, slow computer) so here is the link just in case: Sr20 coolant problem - YouTube He needs an overflow hose... If you still don't believe me, then please go out to your car, pull the overflow hose off your radiator, start the car; give it some throttle and see what happens. I know from trolling that you are one of the smart guys on here; and I am thoroughly convinced that you will laugh (or at least see what I am saying) when you see the video. I am not trying to argue.
#35 |
All I'm saying is that barb is there to push excess coolant/air out when the car starts to boil/overheat the coolant. Air will bleed out automatically because it passes the cap easier than fluid. I'm not arguing that the cap is or having the hose off isn't a part of his issue. I'm simply saying air cannot be reintroduced through that barb once it burps out. That barb is located above the lower rubber seal of the cap but below the upper seal. All im saying is air is being introduced else where in the system.
My SR20VET |
#36 | |
![]() Join Date: Jan 2008
Thank you professor.
Shave your neckbeard and get out of the basement from time to time. Quote:
#37 | |||
![]() Join Date: Sep 2005
I'm taking the challenge! I got video of cold start already, waiting for t stat to open to get warm video. I'm posting no matter the results.
radiator cap is 0.9bar or 13psi There's a few things I didn't show which i realized after the fact, level of coolant in radiator, but it's full. And I didn't show my fans coming on, 85°c/185°f Still think I mixed that shit in Catalina! coldstart cold idle Warm idle I'll edit this post when I get back to the lab, but please comment. Quote:
Sent from my Highly Tuned Vibrant Running Jellybean using Xparent ICS Blue Tapatalk 2
![]() LoverTechnologies "Half Broken Things!" Last edited by cotbu; 11-06-2012 at 07:48 PM.. |
#38 | |
![]() No excuses... The issue is elsewhere like jr_ss already said. I still hope by some chance it's a shit Vatozone [or incorrect replacement] cap; or the Isis radiator being Chinese crap... I will now be quiet and follow ![]()
#39 | |
Yeah, let's hope it not too serious, and this is for you!
