#91 |
http://www.summitracing.com/parts/sum-220985
would that be okay to use as the power steering line? or is it too thin. IF too thin what if you get a little bigger of a hose in the same stuff, will it work? |
#92 |
The line should be fine but IDK about the teflon fittings under PS pressure. However, you ought to use PS hose with PS fittings (links respectively below as examples)
AN Power Steering Hose | ANplumbing.com AN Power Steering Hose Ends | ANplumbing.com |
#93 |
my main dilema is trying to find a line that is either black or braided with steel. The blue line from earls won't match anything in my engine bay. lol
#94 |
A. There's more than just earls in that link provided. XRP makes black PS line, which is what I have.
or 2. buy foiled mylar sleeve for the hose to hide the "awful" blue color and lastly, D. Who cares about color coordination? |
#96 | |
Color Coordination is everything. Seriously though, I despise Red/Blue AN fittings with a passion, along with stainless braided hose. Adds a bunch of extra colors to the engine bay that don't really need to be there. Black Fittings and Hose (stainless fittings are cool too, when needed) are an awesome way to 'hide' all of the lines required to make stuff work. |
#97 | |||
You can run the appropriate fitting to the style of hose in some cases especially with the rubber-based hoses with their fitting equivalents, i.e. swivel seal fittings with XR31 hose or the ti-tech fittings with the prolite hose. I've mixed and matched those all before as they're essentially all the same, but the inner bores vary, with XRP claiming they have the biggest bore over any other AN fitting company which obvious leads to better flow. Quote:
#98 |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
[QUOTE=Beejis60;5417141]I've more important things to do. If he's doing a magazine build, then fine, I get it. Anything else, there really is no point unless you've got OCD to the max. No one will be looking under your hood or under your car that often./QUOTE]
If your driving a KA or some junk like that I'd understand... but im sure this hood will be popped more often than not Here ya go ![]()
#99 | |
Anyway, I have a 500+ rwhp LS2 with plenty of goodies. I still don't care to 'show off' but his does look good and very clean. |
#100 | ||
In the case of Earls Power Steering ends, I've used both XRP and Earls hose and both worked fine, with the only difference being the color. I've also done the same thing with XRP and Earls fittings on Earls prolite hose. Also, the prolite hose is used only on the low pressure line, with the high pressure line being XRP Power Steering Hose. For anyone looking into doing a similar setup, the XRP hose and Prolite are different shades of black (if that makes any sense) and the weave density is noticeably different. Quote:
For reference, the lines are obviously missing in this shot, but it should shed some light on what I'm talking about. ![]() |
#101 |
I generally HATE black engine bays, but the matte looks really good here and mates well with the teal-like vc. I think the only thing that would work with that is anything but black as it's too glossy IMO; ya the red/blue are very popular and may look kinda clashy in your bay, but you could go with all stainless, nickel, or the ti-tech XRP fittings as they have a matte look to them. The PS fitting may look out of place if you had all ti-tech fittings but it seems the PS pump is kinda down and outta the way on that, is it not? I know nothing about those motors...
#102 |
![]() Join Date: Nov 2007
Its def. not a Magazine Build, i am just taking pride in what i do and don't want to make it look like a pile of pieced together shit , although as it currently sits is does look like a pile of shit LOL
#104 |
![]() Join Date: Aug 2013
Hey guys,
Been studying this set up and other on other forums and have just ordered this set up. I was originally going to go with the Chase Bays kit, but it I had been waiting for it since August. Enjuku was nice and refunded me. ![]() So I made my own. Here's the parts list and my "diagram": Total Cost from ANPlumbing.com - $142.00 Shipped ![]() ![]() I just placed the order and have not install it yet, but I just wanted to say thanks to every one in this thread. One benefit to this system is no welding skills are required. I hope to post a install and long term update. Stay tuned! PS: If anyone see's anything wrong that wouldn't allow this to work; please PM or comment.
#106 | |
Try it out but you might have to ditch the washers on the rack and machine the fittings so you get the proper seal at the o-ring. Good luck.
S12 || KN13 || S13 || B16 |
#107 | |
#108 |
![]() Join Date: Sep 2010
From what I can tell from reading this whole thing, NO. U have to machine down the fitting because the hex head is too thick making the shank of the fitting to short and not allowing the oring to mate with the sealing surface of the rack
#109 |
#110 |
Well, fuck. I read that but somehow thought that it was fittings from another supplier that had the issues and earls worked fine. Guess I'll find some to machine these down...
#111 |
![]() Join Date: Nov 2009
I got sick of my rack adapters weeping P/S fluid, so used this as a quick fix on the dyno.
![]() Rated to 2000psi (same as most P/S high pressure hose), haven't had any problems in the 2000km/1200miles I've driven since then. |
#112 | |
Thread Sealants : Permatex®Pneumatic/Hydraulic Sealant I wonder if it may work better, but I wonder if temperatures would affect it.
#113 | |
#114 | |
![]() AMAZON LINK $21 Also, the 54540 only works up to 300* F vesus the 59214 is 400*F; both rated at 10,000 PSI Source: 59214 PDF Downloads 54540 PDF Downloads
#115 | |
#116 |
Solution we cooked up after running into the "threaded section too short" on the aluminum russell fittings we ordered was to re-use both oem fittings on the Factory hardlines. I kept both tube ends on the rack side, cut the tubes 1/16 longer than the fitting itself, got the tube ends out of the fitting and chamfered that end of the fitting. I then put the tubes back in their respective fittings and flared the tube into the fittting giving me something to work with now. I filled up that end of the fittings flat, chamfered both hex corners where they'd meet (for proper penetration) and tig welded me some steel an -6 fittings back to back with these ones. Total cost to me was 12$ for the two an fittings and time. I really wish I had some picture of what I did for details guys would have been simpler to explain. Running flawless for many years now
#117 |
![]() Join Date: Mar 2010
Trader Rating: (34)
![]() Feedback Score: 34 reviews
Ill just add this for those who want to make a full AN power steering set up for half the price. You will need a know someone with a TIG welder, you may be able to get away with a MIG.
First off, take off your PS hardlines from the rack. Next, take a cutting wheel or angle grinder and cut off the ends of the hardline like so. Make sure you have an inch or more at the end of the tube and nut. Clean the shavings that would be in between the tube and outside with sand paper. You will have to clean the tube till its flat and raw material because its going to get welded later. I sanded till the tube easily fell out the nut. Next purchase x2 "STEEL" AN-6 weld-on Bungs and take it to your welder. This can be done with a MIG welder as it is steel. They should cost $2 each, which is a mere 5% of what you would pay for the 2 AN adapters which would probably leak on you. Have your welder weld the bung to the tube from the outside. Make sure you take off the plastic o-rings on the nut before you weld them, they will melt on there. Now you have a power steering rack AN adapter that is OEM reliable. This is 95% of why PS systems leak.. because the AN Adapter being to short inside the rack. I wish i had a pic to compare my OEM AN adapter vs a AN adapter but I can guarantee the AN is half as short. After that you got the hard part done, you just need to get the high pressure line made, feed line, and reservoir. For Pump feed adapter, you can : 1. Go with OP and purchase - Pump High Pressure 16x1.5 Crush Washer -6AN 9919DFJERL or 2. purchase another Steel AN-6 Bung and have your welder weld on the high pressure feed side. The Reservoir leaves you with 2 choices: 1. Purchase a new PS reservoir like I did. eBay $27 ![]() or 2. Purchase x2 AN-6 Aluminum weld-on bungs and x1 AN-10 Aluminum weld-on bungs and follow the method done by OP. This will require you to have someone with a TIG welder. This will leave you with just the AN-10 line to purchase. The oil feed port : 1. If you have a TIG welder, follow OPs method. 2. If you do not have a TIG welder, purchase a AN-10 Female to Barb fitting for the aluminum reservoir above. Then just use the original rubber feed hose, its just a feed line so no need for it to be AN fitted. Hoses : For the High pressure hose, in most cities, there should be a hose shop around your neighborhood that makes these sort of line. In Socal, we have HoseMan all over. Just go in and have them make you a AN-6 to AN-6 High pressure line in steel braided material. This should cost around $40. The return hose from rack to reservoir. Look online like forum and eBay, you just need about 2 feet long, its a -6AN to -6AN. Return hose does not need to be high pressure, regular kevlar braided is fine. Oil feed line, its a AN10 to AN10, again look online. This one is super cheap because its a oil return line for turbos. Hope this helps |
#118 |
Power steering+AN Lines
Thanks man, pictures explain it all better. Only difference is the ones i've done have the tubes flared into a chamfer that's made into the fitting at the hex side to secure i to the fitting,then both ends are filled flat and welded toghether with two passes. And yes MIG works if done correctly. The ps resevoir on mine was relocated on a bracket by the radiator L/H side with fittings welded to it, gets it away from the exhaust manifolds and this all fixes the pump feed line leaking problems that these cars develop enventually with all new teflon braided ss hoses. Oh by the way I forgot to say that mine was also relocated to the a/c compressor area to give space for turbo piping "up there"
#119 |
Have you operated on this rack yet? My friends on Nissan Road Racing say that the weld-on bungs do NOT work and will blow the rack for some odd reason. The only person I know on here that has done the weld on bungs, besides you of course, is Ninocrack and he has not run his car yet.
#120 | |
