#31 |
#32 | |
the duralast kit should work though so there might just be something wrong with the way i put it all together. but it's pretty straight forward, that's why it's hard to believe that i made a mistake lol. eventually, i will order the exedy kit with a new flywheel too, but for now, i just want my car to drive! haha. i'll let you know though, thanks bud |
#33 |
![]() Join Date: Jun 2007
Wondering if your clutch sleeve is too long for the duralast kit. Did you replace the sleeve & bearing when you put the new clutch in?
#34 |
Man w/ CTSV & a Car Seat
^^^Thats what I'm thinking. Shit happened to me before on an ACT clutch. They sent me the wrong TOB and when I put it on the the stock carrier, the setup was too tall. Clutch is basically permanently preloaded so it wouldnt disengage and would slip. I had to drop the tranny, tossed in a shorter Z32 TOB and fixed my issue.
#35 |
![]() Join Date: Aug 2011
If you had not gotten you're problem solved yet, here's some thing to know!
Auto zone products SUCK! They are Nooo good! Every thing you mentioned sounds good to me, that's if you installed it correctly. I believe it's the clutch, I know it's New but thats your problem! |
#36 | |||
that's exactly what it felt like, it felt like the clutch was permanently preloaded so it wouldnt disengage and it would slip, that explains my problem accurately. well i swapped the clutch kit again with another autozone one cause it comes with a lifetime warranty and the new set looks different. i put that in the other day and my car is finally driveable, however, it still slips when i step on the pedal more. not flooring it or anything, but it still slips a bit. i compared the new tob to the oem one in my car and it does look longer, i didnt know that the z32 had a slimmer one, i woulda gone with that lol. but ya, i agree, the duralast clutch sucks! i never want to buy anything from autozone anymore. im just gona start saving up for an exedy stage 1 kit at least. does anyone know how to make the clutch pedal stiffer? it is super soft! lol. |
#37 |
Dude, don't worry about your pedal, fix your clutch problem. But YES, it's easy- get rid of that dampening loop between your master & slave. Pedal feel will be excellent & the system will be far easier to bleed.
#38 | |
NEVER BUY DURALAST CLUTCHES!!! but yeah, im saving up for a real kit right now, but in the mean time, i gotta dive what i got =/ |
#40 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
#41 |
#42 |
Did you break in the clutch first before you start beating on it? You're supposed to take it easy the first couple hundred miles on it. Also, did you turn the flywheel when you swapped clutch?
If you need a cheap clutch, I've had good luck with Valeo clutch for about $110-120. |
#43 | |
and the second set i got is a valeo clutch lol. i guess autozone just rebuilds the clutches. but this one is a lot better than the first set i got. im gona stick with this for a while til i save up for an exedy stage 1 and a lighter flywheel. and yeah i did take my flywheel in to get it resurfaced. but im glad i can drive my s14 again. i just wish the clutch could handle a little more power, oh well. |
#45 |
![]() Join Date: May 2012
Also you got a longer gear ratio when you installed the J30 vlsd which is putting a lil xtra load on the clutch.. the only way to get a stronger pedal is with a stronger pressure plate, or put a spring on the pedal assembly
#46 |
did you replce the prusser plate, and how did you swap the trans in because you might have bent the plate when you swapped the trans witch could cause your slipping i would take it all apart and inspect the clutch and plate
#47 |
![]() Join Date: Jun 2008
no clutch, no matter how cheap, will slip on a stock setup
did u do the 5speed swap? there supposed to be like around 1inch spacing from the clutch pedal to the master cylinder through the firewall if its not spaced enough its not gonna be putting all the pressure it needs and be slightly depressed all the time ![]() |
#48 | |||
#52 |
But if he managed to adjust his pedal engagement to the middle, that means he has the right setup correct? I imagine, if he has the wrong pedal and then he wont be able to adjust the mastercylinder shaft and itll be engaging all the way to the top.
#53 |
I did this when I did my 5speed
I had alot of adjustments but It wasn't enough To compensate I cut the slave nipple like a inch N it was good but clutch would engage way at the top Most likely this could be his problem too |
#54 | ||
k well i just looked at my pedal and it's an s13 pedal. i still dont understand how the pedal would make my car slip though. but i guess i'll try to find an s14 pedal and sell the s13 one lol. |
#55 |
Na dude just add the spacers needed
Look at the pic The 2 studs on the s14 pedal have spacers Just get a bunch of washers or whatever U need the spacing |
