87 Rx7 TII Rolling Chassis (Good 4 track car)
FS: 87 Mazda Rx7 Turbo II Rolling chassis
Located: Avondale AZ Asking: $1400 obo I've had this car for a couple years and haven't done anything to it so it's time to sell it. The previous owner was going to turn it into a track car with a LSx so it's been stripped down. It's a good start for some one wanting to make a track car. The interior and everything else inside was remove by previous owner. I have miscellaneous interior pieces in the car but not a full set(Grey rear carpet, some pillar panels, but front stuff gone). It's not much now but Turbo 2's are getting hard to find. Especially the rear ends. You pretty much have to buy a car to get them. Clean title 87 TII. The Good: -Clean title S4 TII. -Gen 1 Ksport Kontrol Pros with zero miles installed on it. -S4 TII Diff -21 circuit chassis race car harness. Has enough circuits for pretty much anything you need and the wires are all labeled for easy tracing. New and not installed. -Great condition Grey TII door panels(kept inside house for protection) -Good S13 Black Dash(not installed). Minor trimming needed to fit in a FC. -One window converted to electric/Other Manual crank -Spare passenger door/not sure if elec or manual window in it -Rear strut tower speaker enclosure removed so easy access to coil overs or for putting in a cage. -Car is on 16's and 17 wheels. Have full set but mismatched colored 17x7 inch wheels for car. Can be seen on front wheels. The Bad: -Paint is a crappy spray by previous owners and fading to grey on drivers side. -Missing tails but can get some S4's for free for it. -Steering rack not installed, can put one in to move around but it's got surface rust on shaft. -Interior harness was hacked apart by previous owner -No FC dash due to above^ -Hood was cut to allow 5.3 high rise intake to fit. - I think the passenger door hits the front fender. The fender looks like it was bent in near the door hinge. It's a rough sell I know, but I'm asking $1400 obo. The coil overs and diff are the real selling points. If you are staying 13BT, I will include a TII driveshaft and TII tranny with the car. Open to trades but hesitant on other project cars. Will not part out. I need the chassis gone from my house as it's taking up room. For locals, Car is in Avondale if you want to look at it an decide if it's worth your time. ![]() |
| 13bt, fc3s, rx7 |
