![]() Join Date: Dec 2008
Hi guys.
I've owned this car since 2008, and It's been a wonderful project. It's been featured in Superstreet magazine, and countless online blogs. I'm selling it to move on to other things and invest in my new business ventures. Its extremely difficult to part with this car, as its been in my life for the last 9 years. This car spent 6 years of its life in Houston Texas but I recently relocated to NC and finished the paint and body work here, as well as the rest of the build. It's currently located in Raleigh NC. Dyno tuned at MA Motorsports. [B]Makes 466 WHP / 350 WTQ at 18PSI on Dynojet, with a turbo setup, clutch, and drivetrain built for what the EFR 8374 can throw at it. Recently upgraded to 90mm HYPERTUNE throttle body. Exhaust has been changed to Apexi N1 megaphone (world sport turbo, polished, one piece 3.25". Also replaced all brake pads with brand new Project Mu HC+, XRP Pro Plus fuel lines through out the entire fuel system (inside the tank as well) Price is set conservatively at 35,000 . Lowered to 30,000 SOLD!!!! Thanks for looking guys. I've spent over $60,000 in parts & countless undocumented labor hours both paid and personally invested in wiring, plumbing, assembling and fabricating. There are a number of one off parts on this car that CANNOT be replaced, even if money was no object, they simply do not exist. (Apexi one piece Megaphone Exhaust, CSG S14 tail lights, GP sports front Aero, etc) VIDEO OF DASH DISPLAY IN ACTION https://business.facebook.com/Affini...5779190541513/ On to the specs: Motor 1998 Skyline R34 GTT RB25DET Neo RB26 Valve Covers Powdercoating for valve covers HKS Timing Belt R33 Front Subframe Syko Performance mount kit. Transmission & Drivetrain R34 RB25DET Pull Type Transmission NISMO R34 GTR G-MAX Twin Disc KAAZ 2-Way Super LSD Driveshaft shop aluminum driveshaft Stainless Steel Braided Clutch line, Brake lines Billet Differential Bushings Energy Suspension - Subframe & Steering rack bushings Peak Performance Poly Transmission Mount Suspension Megan Racing - Race Coilovers w/ FEAL camber plates (This was going to get replaced as one of the last things before the car saw track time) Voodoo13 Billet Front tension rods Voodoo13 Billet Rear upper control arms Voodoo13 Rear Toe links Voodoo13 Billet Rear traction rods Peak performance inner & GKTECH outer tie rods SIKKY RB Swap front sway bar Fuel System Walbro 400 LPH Radium walbro pump adaptor fitting to 6an Holley Hydramat Injector Dynamics 1000cc Injectors Radium fuel rail AEM Fuel Pressure Regulator -8AN feed / -6AN Return Custom Crimped XRP Race hose with gold fittings Chassis BadFish Performance Roll cage BadFish Performance Rear fender mini-tubs BadFish Performance Sheet Metal Interior Panels Pride Motorsports / Robot Racing Dry Carbon Dash Recaro SPG replica seats Takata 6 Point Profi harnesses Street Faction Front & Rear Bash Bars W/ tow strap mount Street Faction Heel Up Plates Street Faction Seat Rails Momo MOD70 steering wheel Cusco steering wheel Hub Carbon Radiator Cooling Panel Aerocatch Hood & Trunk Latches K-Sport Air Jack System Wheels & Tires Rays TE37SL 18x10.5 +15 Front Rays TE37SL 18x11 +18 Rear Falken AZENIS RT615K 265/40/18 Front Falken AZENIS RT615K 315/30/18 Rear Turbo Setup Borg Warner EFR 8374 .92 AR IWG Turbo Turbosmart Internal Wastegate Actuator (2 port) Turbosmart 4 port wastegate solenoid Raw Brokerage Billet Twin Scroll EFR Manifold BMRS / XRP Engine fluid hoses Greddy Intake Plenum Hypertune Throttle Body Custom Core Invert mounted Intercooler Apexi World Sport Turbo Exhaust MA Motorsports Oil Catch Moroso power steering Reservoir Cooling MOCAL Oil Cooler GREX filter housing Griffin Aluminum Radiator Flex-a-lite dual 12" Pusher electric fans Raw Brokerage Silicone Radiator Hoses Nismo Thermostat Electronics AEM Infinity Engine Management Monitoring of Oil press & Temp, Fuel Press, MAP/boost, Intake air temp, Wideband, Water temp, AutoSport Labs Race Capture Pro II Telemetry and Race Dash Modified Wiring Specialties PRO NEO Engine Harness Custom Chassis Harness With ARC 8000 Touch Switch Panel Optima Battery + Bracket Aero GP Sports G-Four Front bumper cover (Last authentic one in existence) GP Sports G-Four side skirts GP Sports rear bumper cover JDM OEM S14 Kouki headlamps URAS Type 1 grille Ganador powered side mirrors Yashio Factory Carbon Hood - Kouki ChargeSpeed Front Wide Fenders +20mm ChargeSpeed Rear Wide Over Fenders +50mm CAR SHOP GLOW - Hand Made LED Tail lights SARD GT 1700mm Wing Annointed Aero Carbon fiber front splitter RIZE JAPAN carbon fiber canards New Windshield Brakes Project Mu 355mm SCR two piece slotted rotors Project Mu 4 piston forged calipers with brackets Project Mu Teflon brake lines Project Mu B-Spec racing brake pads x8 300zx 2 piston rear calipers and rotors 300zx Z32 Brake Master Cylinder Project Mu HC+ brake pads front and rear ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by whatbrokethistime; 10-10-2017 at 10:06 PM.. |
![]() Join Date: Aug 2005
Trader Rating: (18)
I almost fell out of my chair laughing when I saw 40k but then I scrolled down further saw the car and parts list. Well done sir!
DON'T BE UPSET WITH THE RESULTS YOU GET FROM THE WORK YOU DIDN'T DO. |
![]() Join Date: Jun 2003
Trader Rating: (129)
its been a long time since i saw an s-chassis that justified a price north of $30k.
this one would be a steal for $40k. |
I was thinking the same thing, but it does say FEAL/ Megan, so I'm assuming they've been reworked by Odi?
#19 |
#21 | |
Just because you are unaware of it, takes nothing away from his quality. |
#22 | |
Let alone copying zeal name to feals good man |
#23 | |
![]() Join Date: Nov 2004
Trader Rating: (53)
anyway back to thread topic. Your car is awesome. Really doubt you will get 40k for it though.... S Chassis just don't get that kind of love by gen pop. I wish you the best! |
#24 |
I've seen a few pics of this car before and always loved it, but I have to ask: for $40k, where's the motor work? Rods, pistons, oil pump.. anything? I have an 8374 as well, and you're holding that thing back!
#27 | |
The car violently spins it's 315's with the onset of boost using the 8374 and with the weight of the car more power really isn't needed. It's not a highway car, and I really enjoy its current drivability thought the twisties. |
#30 |
Not sure why this video will not show up properly... Can anyone see it?
https://youtu.be/dV04OevYvY8 https://www.youtube.com/watch?v=dV04...ature=youtu.be Last edited by whatbrokethistime; 04-17-2017 at 11:26 PM.. |
