#1 | |
![]() Join Date: Jul 2005
Will not start
*EDIT: Here's my revised post.
613DriftWerks.ca Last edited by Ninjabread; 04-04-2008 at 05:38 PM.. |
ok small update, it started with the fuel pump fuse disconnected and ran briefly until there was no more fuel.
Now, won't start weather or not fuse is put in.
613DriftWerks.ca |
Ya, it's a weird situation. Before I put her away for winter, I knew there was an issue. The alarm on it was super shady, and as soon as I ripped the brain out, it started right up. But it's all taken out now (the alarm) so that's not the issue.
I know I have some loose connections at the ecu plug (no clue how to fix loose pins), so those could be the culprit for the injector not firing, or the starting issue. I'm just lost because I don't know where to start.
613DriftWerks.ca |
Sounds like an injector problem, test the resistance on each injector. Should be ~11.5. Also if your coolant temp sensor is bad itll flood the cylinders causing it to crank but never fire up until the gas is evaporated. Also try pulling your injectors and checking the smaller o-rings to see if they are cracked or warped.
O-rings all checked out fine (actually look brand new, i think they are)
and I checked resistance, i set my volt meter to rx10 (don't know if thats the right setting) and i got just a bit over 10ohms on each one.
613DriftWerks.ca |
ok so, two things I've learned this morning.
code 34 - knock sensor (gotta fix that, but not related) code 13 - coolant temp sensor: COULD be related, as a defective one causes rich conditions which may flood the motor annnd apparently my ecu plug was snug, but it likes being very tight... I discovered that when checking for codes, it seemed to blink randomly unless I held it down, so I tightened it some more and sure enough lights were giving codes. Only thing is that the little screw that accepts a flat screwdriver on the ecu is missing, so I can't turn the screw back to normal haha. anyway off to cady tire to get new spark plugs and a CTS and well see if she fires!!
613DriftWerks.ca |
