![]() Join Date: Feb 2005
MAF testing?
alright i've been searching on here for about an hour now, and have found little to nothing on HOW to test a MAF. I have a stock KA24DE in an s13.
anyone have any info on how to test the maf and what o test it for?
![]() Join Date: Jul 2007
Trader Rating: (106)
It is pretty damn difficult to test a MAF sensor. Some are pretty much un-testable. I'll check mitchell and see if there is a way to test the s-13 MAF sensor or if it is a process of elimination. MAF sensors rarely go bad though, especially on 240's.
well, mine is doing the whole running good when the maf is unplugged bit, and there are NO and i mean NO vacuum leaks on this car.
#6 | |
![]() Join Date: Aug 2005
Unplugging the MAFS basically puts the car in a 'limp' mode. Thus masking other problems. It could be something like the coolant temp sensor. Hell, I had the completely wrong ECU on my car, but when I unplugged the MAFS, it idled GREAT. |
:edit:
taken to pms. bomber, thanks for the offer, i'll hit you up asap when i find out more.
![]() Join Date: Oct 2006
You need to get a voltmeter!
With the key in the on position Check the black/white stripe wire for 12 volts. Then check the white(signal)wire for around 0.5/0.6 volts and heres the good part! Blow into the maf with the voltmeter still hooked up and your voltage should rise as you blow into it! And then last check for a good ground on the black wire. I hope this helps and this is the best way to see if your maf is realy working without doing the whole plug it in plug it out/borrow your friends maf guess work. You can also check your ecu for codes! Good luck!!! -mike- |
#13 | |
![]() Join Date: Sep 2002
Swap MAF with a friend, if the problem follows the MAF, replace it... If not, keep searching for possible cause
Ive tried 3 mafs, one of which came out of a runnng car. I'm just trying to double and triple check my shiznat.
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
if ur gonna check voltae of th emaf and dont wana damage hewires just do what i did and puncture a small hole in the wire with a tack or push pin
PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r
