S13 SR20DET VDO Tach adapter?
Hello. I am wedging a S13 SR20DET into my Locost. I have a factory S13 engine wiring harness. Will I need a Tach adapter to install a aftermarket VDO tachometer?
Thanks guys. I am new to SR20DET's and your forum rocks! It has answered about a million of my questions already. My car will be street legal and look something like this when it is done.
It only weights 1500LBS, so even a stockish SR20DET will make it a blast to drive :-) The new Caterham Seven 620R has similar power (accept the power is not Nissan enough for my liking) http://www.youtube.com/watch?v=8CRdQA7R9xs |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
Yes, most likely you will need a tach adapter. The only ones that don't require it are the fancy ones from Apxi and Defi that are fairly expensive
http://essencegarage.wordpress.com/ |
Do you know what kind of signal the SR20DET makes? With these adapters your usually converting the signal the car makes into the signal the tachometer requires. Thanks Jason
